01-03-2016, 02:45 PM | #1 |
Rep 64
Will 467m Wheels fit on M4
I'm trying to figure out if the 467m wheels from an X5 would fit my 2015 M4. I have these wheels in my garage (with tires) just laying around. Before I go unmounting the tire from wheel and before I buy a full winter setup, I wanted to know if they would fit.
M Wheels 437m Front 19x9 - 29 offset Rear 19x10 - 40 offset X3 Wheels 467m Front 19x9 - 37 offset Rear 19x10 - 53 offset I have 15mm spacers in the front and rear. Would the 467m wheels fit? |
01-03-2016, 03:46 PM | #2 |
349
Rep 2,347
Drives: TT Flat Six
You would get a more definitive answer if you just attempted to bolt one up.
With spacers you could make the size / offset work, but the concern would be brake caliper clearance. And of course the SUV tires would need to be swapped for m3 size tires if the rims fit. |
01-04-2016, 03:35 PM | #3 |
320
Rep 1,061
The other issue is the center bore (hub centric) diameter 74.0mm vs 72.5mm as the standard BMW car bore. The one exception is the E39 which is 74.0mm.
This problem can be corrected through specialized spacers or through hub centric rings. |
