01-03-2016, 01:36 PM | #1 |
Rep 8
E93 m3 not starting no electronics working PLEASE HELP
HI ALL,
I left my 2011 E93 M3 parked for about 2 hours when i came back i heard my alarm was on i try unlocking the door with the remote control but no luck i had to open the door manually with the key then the alarm shut off. i insert the key and press start stop but nothing comes on.. no electric..no dashboard lights nothing next i jump start the car for about 15 minutes and still no reaction nothing is turning on what should i do? the car seems completely dead.. maybe i left the car door open? and it drained the battery? anyhow it is not turning on whatsoever not even the dashboard lights if anyone could help i would really appreciate it I do not have access to the trunk as there is no key hole |
01-03-2016, 01:51 PM | #2 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
I had this happen to me very recently and it was very annoying especially after I had roadside assistance tell me my battery was perfectly fine.
I had the IBS cable replaced but that didn't fix it. For me when I went to use comfort access it would trigger the car alarm. I've started using the keyfob to unlock only. Try this: * open up the fuse box and push every fuse in * wiggle the battery cable connecting to the fuse box as it might have gotten corroded * disconnect IBS cable - see if power comes back. All you need to do is unplug the small jumper like wire. My problem didn't come back after I messed with the fuse box. Fuse box is in the glove compartment by the way. You'll know you've fixed it because all the cars electronics will suddenly wake up |
01-03-2016, 01:54 PM | #3 |
2147
Rep 2,527
Also some people had an issue where their EDC module went bad and was applying a voltage to the wake up line. You could try disconnecting that to see if you get power restored too.
Good luck, there seems to be a bunch of us starting to see this issue. |
