01-02-2016, 05:02 PM | #1 |
433
Rep 1,286
Is there an elegant/simple solution?
Probably for many of us irrespective of whether we are the original owners or not the screw holes for the airbox and brake fluid reservoir are probably stripped out. Mine is totally courtesy my local BMW dealer. There's otherwise nothing wrong with my airbox or brake fluid reservoir cover (it's part of the upper engine trim not the cover that's stripped), but each and every screw hole is stripped out since it's plastic and the mechanics in their rush apply too much torque.
Is there a simple fix to this? I'd really like to have a metal threaded insert that would still work with the oem screws. Anyone have a fix for this? |
01-03-2016, 03:50 PM | #4 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
As 'vsix' mentioned, you can fill the stripped screw hole with a suitable epoxy, let cure, and then drill a pilot hole through it. At this point you can either tap the hole or possibly run a self-tapping screw through to thread the hole. The trick here is certain epoxies thread tap better than others. Some cure to a nice plastic-y texture while some are too brittle to really tap smoothly. I've used a 10-minute two-part liquid epoxy and let cure for 24 hours before drilling and tapping. Make sure it is fresh and thoroughly blended in the recommended ratio (generally a 50/50 mix of the two parts).
The nice thing about this fix is that the original BMW fastener is still used and the fix is practically invisible when completed. Cost is less that $10 plus your labor. |
