01-02-2016, 02:23 PM | #1 |
131
Rep 458
F80 Wheel Hop 1st and 2nd gear (6MT)
Hello and Happy New Year!
Granted it's only 44F here in NJ but in the higher RPM range in 1st and 2nd (6MT) gear when I loose traction (DSC off, MDM off) the rear wheels stutter and hop which is driving me nuts. When it occurs I'll come off the gas pedal but it's extremely frustrating. I've only seen one other thread about this and some mentioned spacers helped (not sure why spacers would help), but are other F80/82 owners experiencing this? Even 2nd gear pulls, I'll spin the tires after 5k RPM, the car in general breaks the tires loose easily but the wheel hop is bad. I know IRS (Independent Rear Suspension ) are prone to this stuff; it reminds me of the 99 SVT cobra's in which I helped a buddy swap it for a straight rear. Didn't expect this on a '16 M3 Anyone else ? Trans choice shouldn't matter butu any thoughts/solutions? Lowering tire pressure? Spacers? Ditch the Continentals that it came with?
Alpine White '16 M3 6MT
01-02-2016, 03:16 PM | #4 |
131
Rep 458
Seriously man c'mon this isn't "user error" but a one user amongst others looking for some solutions
01-02-2016, 03:17 PM | #5 |
131
Rep 458
Under the same conditions as I described in the original post?
01-02-2016, 03:43 PM | #7 | |
131
Rep 458
01-02-2016, 04:04 PM | #8 |
162
Rep 388
Yup under same condition. It was about 43 degrees here, I wonder how much did the summer tires contribute to the wheel hop since it was cold. I hope I didn't break anything since I'm still in the break in phase with 300 miles.
01-02-2016, 04:21 PM | #9 | |
131
Rep 458
01-02-2016, 05:12 PM | #10 |
1745
Rep 1,700
Wheel hop is harmonic vibration. Nothing that can really be done about it since GM patented asymmetrical links to each wheel as a way to stop it on their V Series cars. I have it in my car too in some situations. It will tear apart the rear end of your car if you don't get out of the gas when it starts.
01-02-2016, 05:42 PM | #11 |
1798
Rep 4,216
Cold tires? Cold pavement? Your ability to get traction is completely dependent on the conditions in which you are driving relative to your throttle modulation (and steering input for performance driving). With any RWD car as capable as your M4, expect better results in warmer weather.
2020 F87 M2 Competition /l\ LBB /i\ Executive Package 2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV BMW CCA Member |
01-02-2016, 08:26 PM | #12 | |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
/// M3 |
01-02-2016, 08:41 PM | #13 | |
707
Rep 816
Try again in the spring, just make sure to keep the TC on. Otherwise the user error you'll experience could be much worse than wheel hop...
01-02-2016, 11:20 PM | #14 |
99
Rep 382
Front engine, RWD and stiff springs/dampers = not uncommon to get wheel hop (aka axle tramp) at lower speeds on low-grip surfaces. This problem isn't exclusive to the F8X chassis - my E90 M3 did it a lot with the stock suspension and KW V3s. My Supra BPU+ MKIV did it too but that was 15 years ago
01-03-2016, 06:55 AM | #16 |
200
Rep 286
Has happened to me before as well as on a couple other cars I've owned. Never had a problem with the rear end from it. It's all dependent on the setting of where you're driving. If it's 95 degrees out with a set of warm tires, obviously it doesn't happen much. But that's now always the case for us guys in the northeast. I really don't think it's that big of a deal.
Current:
2020 M2 Comp (AW) 6MT Previous: 2018 Mini Cooper S (F56) (grey/black)6MT 2015 NC Miata club PRHT 6MT 2007 911 Carrera 2 (black/tan) 6MT 2017 Grand Sport (blue/white/red) 7MT 2015 BMW M4 (BSM/SS) 6MT 2011 C63 AMG (black/black) 7A |
TractionControlDelete4594.50 |
01-03-2016, 09:59 AM | #17 | |
1003
Rep 3,396
01-03-2016, 10:06 AM | #18 |
1384
Rep 3,358
No wheel hop here... even on R Comp tires below their operating temp.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
01-03-2016, 10:25 AM | #19 | |
Roofless & Ruthless
1356
Rep 1,480
Drives: 2015 AY 6MT F83
I've experienced it with DSC on but never with the nannies off. I've always assumed that was the byproduct of the traction control system trying to get things under control.
01-03-2016, 10:50 AM | #20 |
207
Rep 497
Definition according to GM's patent:
Problematically, axle shafts frequently exhibit “powerhop” when a large amount of torque is applied thereto. Powerhop typically occurs when tire friction with respect to a road surface is periodically exceeded by low frequency (i.e., below about 20 Hz) oscillations in torsional windup of the axle shafts. Powerhop produces oscillatory feedback to suspension and driveline components and can be felt by the vehicle occupants, who may describe the sensation as “bucking,” “banging,” “kicking” or “hopping.” |
01-03-2016, 10:59 AM | #21 |
736
Rep 2,134
It's user error. Sometimes it happens to me and others it doesn't.
If I got out of it and stopped the hop and then back in it, it's fine. If it doesn't happen every time or can be corrected instantly, then it's user error in my opinion. |
01-03-2016, 11:15 AM | #22 | |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
/// M3 |
