01-02-2016, 09:59 AM | #1 |
1563
Rep 2,869
Can I fit Style 37 on E92 M3 Competition?
I have NIB 1995 E34 Forged M Parallel. I want to use them with 245/40/18 front and 295x35x18 rear. The rev per mile will be the same as OEM Style 359.
Will it work? Front is 18 x 8 ET 20 Rear is 18" x 9 ET 22 TIA Rami Last edited by rhyary; 01-03-2016 at 11:38 AM.. |
01-02-2016, 10:19 AM | #2 |
62
Rep 398
Is a 295/35 able to be fit on a 9" wide wheel? It seems like that would be outside of what manufactures say are the width range and would be very squeezed. Even on a 10" wheel a 295 is normally kind of squeezed so people normally run a 10.5" or 11"
01-03-2016, 06:19 AM | #5 |
11586
Rep 12,728
i've always liked those wheels, but they are too skinny to run on the m3. they are too skinny for even the oem tires and the car will handle sloppy. it can work if you don't mind it being a little sloppy (granted that they fit).
Instagram; @roastbeefmike
01-03-2016, 11:49 AM | #6 |
1563
Rep 2,869
On the track I understand sloppy, but then again I have the 359s and I can make them the track wheels.
On the street it can translate for a better ride, and on non-perfect roads even better traction. 265/40/18 is a perfect rev per mile fit: 790 275/40/18 is a bit over by 3% : 814 275/35/18 is a bit under by 1.2% : 780 If anyone has experience with these combination...your input is welcomed |
