12-24-2015, 09:46 AM | #1 |
26
Rep 63
Powder Coated Rims Causing Rotor Wear?
Hello - A friend of mine has her rims powder coated (maybe painted?) on her BMW. She's had to replace her rotors every 10,000 miles. The dealer is now telling her that the modified rims are the reason for the rotor wear and have voided her warranty until she replaces everything to stock.
I guess they are saying that the part of the rim that bolts to the hub is painted/coated and that is causing the issue? This doesn't make any sense to me, was hoping someone might have some experience here that could provide some feedback. Thanks! |
12-24-2015, 10:11 AM | #2 |
386
Rep 2,989
You definitely want the rim and hub mating surfaces to be clean/unpainted. However, I'm baffled by how such a thing would cause rotors to wear prematurely. I could see how it could throw the wheels out of balance, but that shouldn't impact the rotors.
Seems to me that the dealer is looking for a way out of warranty/"free" maintenance work |
12-24-2015, 10:32 AM | #3 |
1205
Rep 2,105
Drives: M4 MW/SO 6MT, E46 M3 AW/IR 6MT
Sounds like a case of "you need a new engine because the headlight fluid is leaking"
MILA | E46 BMW M3 | AW/IR | 6MT | KW V3 | CSL | Vorsteiner |
EMILY | F82 BMW M4 | MW/SO | 6MT | M Carbon Ceramic Brakes | M Performance Exhaust | |
12-24-2015, 11:31 AM | #4 |
1569
Rep 29,202
I've always heard that the part of the wheel that's sits on the hub should be unpainted.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
12-25-2015, 12:03 AM | #5 |
1357
Rep 3,349
Yup..
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
12-26-2015, 02:35 PM | #6 | |||
1163
Rep 2,561
How many rotors require replacement every 10K miles (ridiculously short, even if the person is tracking the car ever other weekend)? All four, or some more than others? Are the rotors getting worn? Exhibit warping/shaking under braking, and thus assume to require replacement? Quote:
What they likely told the owner is that they suspect that whatever the problem is, it's likely caused by the aftermarket wheels. Quote:
You really need to start with stating what the alleged problem is. There are a lot of contradictory claims in the above narrative (warranty voided (not), rims causing rotor wear (not), rotors require replacement every 10K miles (likely not), etc). Lets get the facts straight first, THEN we will start jumping to conclusions! a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
