12-17-2015, 01:34 PM | #1 |
Rep 23
DCT Initial Acceleration
After the car has sat overnight, following startup, it is really necessary to race the engine to get the car to move either forward or in reverse. Once it has cycled through several gears or once the the car has warmed up & has not completely cooled off, it instantly moves in either forward or in reverse as soon as you have selected a gear. Is this normal, if not does anyone have a suggested cure for the problem?
12-17-2015, 01:51 PM | #2 | |
413
Rep 1,178
Same for 1st gear although i do apply a bit of throttle very minimal. |
12-17-2015, 05:39 PM | #5 |
8912
Rep 4,107
Just to clarify, as soon as you put the car in D or R it starts to move? If so, that is not normal unless you are pressing the gas pedal. When initially put into D or R, both clutches are engaged until you press the gas...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
12-17-2015, 07:41 PM | #6 |
Rep 23
it does not start to move when put into gear immediately after starting it if it's sat overnight or after sitting in the parking lot at work for a normal workday; I have to give it a substantial amount of throttle to get it to move as I back out of my driveway in reverse and again as I as I put it in D to go forward down the street or if at work as I put it into D to pull out of the parking lot. I'll check the exact revs tomorrow morning.
01-08-2016, 10:39 AM | #8 | |
Captain Fatbelly
1423
Rep 1,994
01-08-2016, 10:44 AM | #9 |
50
Rep 323
Drives: 2009 E93 M
For my 2009 E93 M I have to nudge the gas pedal a bit, but certainly not revv it...
01-08-2016, 10:47 AM | #10 | |
4467
Rep 7,110
01-11-2016, 12:45 PM | #11 |
591
Rep 534
my car does not move when put in gear. it needs some throttle to get her going. Not normal op.
Now not m cars will start to lurch forward. My old 328 did exactly what you are saying. Maybe you car has been hanging around to many volvos
01-11-2016, 01:04 PM | #12 | |
Stop the hate, get a V8
3850
Rep 8,625
That's the expected behavior. The M-DCT has the "low-speed assistant" that means you should only have to tap the gas pedal very lightly & briefly for it to let the clutches out and creep forward (or back). It's great for inching forward in traffic or in parking lots.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
01-12-2016, 10:04 AM | #13 |
48
Rep 207
It sounds to me like he is referring to transmission slip. I'm having the same issue. It feels like the clutch is slipping when the car is cold. Once warmed up its less apparent. I'm having mine checked next week as I'm also experience a slight delay on downshift engagement when in S4 or S5. I would have it looked at.
01-16-2016, 04:31 PM | #14 |
Rep 37
Mine does the same thing when it's cold outside. Only when first starting up in the morning or after work and only when putting it in drive. It doesn't do it going into reverse. It feels like the clutch is slipping a little. If I put it in drive and wait for a second it helps. I never noticed it doing this in the warmer months.
01-18-2016, 09:41 PM | #15 |
875
Rep 611
Drives: 2013 M3 coupe' 6mt
Maybe this cold start behavior is there protect our rod bearings?
memories: '71 2002 (new), '72 Bavaria, '74 2002tii, '00 540i Sport |
01-20-2016, 08:17 AM | #16 |
63375
Rep 24,678
Thank god
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
01-20-2016, 08:32 AM | #17 |
4467
Rep 7,110
On my second box (brand new while previous also was with fresh <20k miles) and both behaved the same way. When cold, clutch slip. Gentle tap on the throttle to first engage or wait for cold cycle to end and all fine.
No reason to force slip if not needed. |
01-22-2016, 05:28 PM | #19 |
203
Rep 538
What is force slip ?
01-23-2016, 02:41 AM | #21 |
4467
Rep 7,110
