12-15-2015, 05:20 PM | #1 |
22
Rep 130
throttle actuators failure
Hello all,
Well it finally happened. I have read so many horror stories on this forum on critical failures of the E9x M3's that to say I had anxiety about the car is an understatement. And like so many stories ive read, mine happened without warning for seemingly no reason. I was driving on the freeway when I felt a slight hesitation while at partial throttle, so I figured the car was still cold it probably need a little bit more rpm's to stay happy. I downshifted so the rpms were around 3k and thats when it happened. Sudden jerking, engine shutoff, the dashboard lights up like christmas, and my I-drive showing all the warnings. After being stranded for a couple hours I was finally able to get it to a local shop where the codes were read and the cause was found. It was found that one of the actuators failed and kept one bank completely open at full throttle. It appears that the circuity on the broken actuator had burned itself out. I opted to replace both actuators just in case. After about three days, and a 3k repair bill the car is up and running. But my anxiety has only gotten worse about things like rod bearing failure. I am almost hesitant to drive my car A little info on the car 2009 m3, 73k, 6spd, competition pkg, technology pkg, cold weather pkg, aFe intake, rpi scoops, dinan supsension, meisterschaft GTS rear. |
12-15-2015, 05:45 PM | #2 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
Oh man, 73k miles, you just missed the 7-year/70k mile emissions equipment warranty in the state of California. (This covers throttle actuators as part of "emissions equipment".) Sux.
12-15-2015, 05:46 PM | #3 |
5234
Rep 10,616
I think you just have to accept that these complex, high performance cars need some expensive maintenance as they age. You paid too much, but that is another matter. Actuators cost about $800 each and an experienced shop can swap the pair in 2 hours. If they replaced the TPS as well, add $100 each and up the labor to 3 hours total. Call it 4 so they don't have to work too hard. Bill should have been in the $2200 range.
Maybe find another shop to do the rod bearings. After that, you should be fine for a while. The only other repair I have done is a fuel pressure sensor that cost $100 for the part. I did change all the fluids as preventative maintenance and the spark plugs. |
12-15-2015, 05:50 PM | #4 | |
1889
Rep 5,506
The cost of the actuators themselves have gone up in price as well. They cost $950 ordered online and $1200 at the dealer.
Auto Detailing Enthusiast!
12-15-2015, 05:56 PM | #5 | |
22
Rep 130
12-15-2015, 05:57 PM | #6 | |
22
Rep 130
12-15-2015, 06:02 PM | #7 | |
1889
Rep 5,506
Luckily I was under emissions warranty but I paid out of pocket to have the 2nd one replaced as preventative maintenance. They agreed to price match the online price of $950 for the part itself. Ended up $1200 out of pocket. What shop did you go to?
12-15-2015, 06:11 PM | #8 | |
22
Rep 130
12-15-2015, 06:38 PM | #11 | |
1889
Rep 5,506
And the replacement actuators will probably burn out just as the originals did since they are the same thing.
12-15-2015, 07:58 PM | #12 |
Track Whore
542
Rep 1,640
You guys are still overpaying.
http://huskerparts.com/2008-bmw-m3-b...27838085-item/ $788 + $12 FedEx |
12-15-2015, 08:13 PM | #13 | |
289
Rep 1,536
It used to be sold on BMW of Morristown for $750 shipped, one year ago but for some reason it went back as any other place |
12-15-2015, 09:54 PM | #14 |
3274
Rep 6,723
Well maybe since you replaced your known good working unit, try to sell it and recoup some of the expense.
Some of these things are worth trying to do yourself to save money. |
12-15-2015, 11:14 PM | #15 |
997.1TT
1003
Rep 1,672
you are all overpaying. My local dealer can get them for me for $700 each. Granted that is in Germany and it's actually €650 vat free, but whatever. I'm glad I don't have to pay some of the prices you all pay.
12-16-2015, 02:00 AM | #16 |
Track Whore
542
Rep 1,640
12-16-2015, 02:27 AM | #17 | |
4467
Rep 7,110
Cheers |
12-16-2015, 02:53 AM | #18 | |
1889
Rep 5,506
Most of the time the electronics board burns out like the original poster shows. In that case, unless you're talented in soldering microchips, you need to buy a new unit.
12-16-2015, 04:22 AM | #19 |
No military grade
58
Rep 619
Best of all (just in case you did not know): You would not need any replacement of actuators or electronics had you oiled the throttle valve bearings in the first place.
Contrary to urban legend, the actuator gears are not as bad as reported over and over again. Matter-of-fact, the causality is like this: 1. The throttle valve bearings become dry and stiff. 2. Thus, the actuator have to apply bigger force and wear faster. 3. When the force becomes too big, the actuator motors draw too much current and blow the driver transistors in the electronic unit. So, there is no need for an aftermarket replacement of actuator gears. Just oil your valve bearings once a year and you'll be set.
boost4boobs66.50 |
12-16-2015, 06:35 AM | #20 | |
5234
Rep 10,616
12-16-2015, 06:37 AM | #21 |
No military grade
58
Rep 619
That is correct - once you have the gears wear it's too late. However, for the people who had their actuators and/or electronics replaced: Lubricate the throttle valve bearings regularly or you will face the same problem in about 3-4 years from now.
12-16-2015, 07:28 AM | #22 |
324
Rep 488
Drives: 2011 E90 M3 6MT
Is there a documented procedure? If they are easy to remove/replace, I would guess lubricating them would not be difficult.
