12-07-2015, 06:17 PM | #1 |
612
Rep 1,326
Problem with traction on 1-2, 2-3 shift (DCT)
My current wheel/tire setup is 19x9.5 265/35/19 fronts, 19x10.5 295/30/19 rears with Michelin PS2s. Tread life is around 6/32" front, 4/32" rear if I had to guess (will check with a gauge later). Alignment settings are -1.9 front camber, -1.0 rear camber, I believe slight toe in for the front, and 0 toe rear.
I'm having an issue with traction in S4 mode, where my rear end would break loose on 1-2, or 2-3 shifts. When the rear end breaks loose the car will want to slide (I think left) until traction control kicks in to keep the car straight. It's actually pretty scary - sometimes I end up partially in the lane next to me (I don't even bother going in S5 mode). The car is NA with test pipes, drop in air filter, GTS transmission tune, no aftermarket tune. Do I need new subframe bushings? Perhaps my alignment is out of wack? Or do PS2's just generally suck? Anyone else experience similar issues? Any help is appreciated. Thanks in advance.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
12-07-2015, 06:26 PM | #3 |
612
Rep 1,326
I usually don't punch it until the tires are warmed up after driving at least a few miles. The weather has been colder lately, but I've had the issue when the weather was 10-20 degrees warmer as well. I'll check the tire pressures tonight.
12-07-2015, 06:36 PM | #4 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Check your tire pressure. Pilot Super Sports are much better for straight line grip, particularly when cold. So when you need new tires consider PSS.
If it's really cold out, you are gonna spin no matter what at WOT. If you want zero spin, get R888's.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
12-07-2015, 06:50 PM | #5 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
Umm, any car that won't break the tires loose on a 1-2 shift is underpowered. Be thankful yours is running as the horsepower gods intended!
I have PS2s on my Viper and they behave exactly as you described, with a little side step when suddenly breaking traction under hard acceleration. Same ViscoLok limited slip diff as an M3 too. So fun. |
12-07-2015, 06:52 PM | #6 | ||
612
Rep 1,326
12-07-2015, 08:48 PM | #7 |
3274
Rep 6,723
12-07-2015, 08:49 PM | #8 |
3274
Rep 6,723
PS2 new tread depth is 8.5/32"
4/32, see below. Taken from Discount Tire website http://www.discounttire.com/pdf/trea...geDownload.pdf |
12-07-2015, 10:31 PM | #11 | |||
612
Rep 1,326
i checked the tire pressures and they came in around 31 psi front and rear. i used a digital tire gauge. that seems too low doesn't it? what kind of impact would that have on traction? Quote:
i do agree i should not have traction issues with my mods.
12-07-2015, 10:40 PM | #12 |
99
Rep 357
Car will spin, its a good thing, just have to feather with it and play with it. My car breaks all traction on 2-3 shift even with AD08's if I keep it pinned... But its also got an ESS kit
12-07-2015, 10:48 PM | #13 | |
3274
Rep 6,723
I'd go 33F and 35R. Basically with the lower PSI, it "should" get you more usable tire width to drive on which in turn should actually give you more grip however, also depending on your wear pattern, you could be running too low pressure and cupping the inside part of your tire causing you less grip, you'd be gripping only the shoulders of the tire. I think for the most part, your car is fine and reacting to the cooler weather. Even though it's dry outside, for the most part, the streets are fairy cold. I would consider replacing those tires at some point and moving to PSS as they are superior to PS2's. That's my $.02 anyway |
12-08-2015, 06:58 AM | #14 |
3431
Rep 6,771
Drives: 2016 BMW i8
31 is fine. But you can can lower the rears a little down to 29 to get more grip. Essentially by lowering your rear tire pressure you are lowering "oversteer" in track terms. In this case you are also gaining traction straight line. With a blower and 570 wheel, now in the winter I'm spinning more in 1st and on the 1-2 shift but it isn't that bad now that I have MRF solid subframe bushings with PSS tires. But I still need to dial down rear tire pressure a little. I no longer spin the 2-3 shift in winter and I did before the subframe bushings. But since your motor is NA, try PSS first before considering subframe bushings. Install on that is pricey.
12-08-2015, 01:37 PM | #15 |
300
Rep 247
I am running P Zeros on a 6MT and I lose traction from 1-2 as well as sometimes losing traction through the rev range in 2nd. Only get a small amount of movement from 2-3rd. Love it.
12-08-2015, 01:56 PM | #16 |
E92 M3
99
Rep 508
Drives: (2) E92 M3's & F30 320i
Maybe you're TC module is glitching out or even damaged
12-08-2015, 01:57 PM | #17 |
3221
Rep 6,218
first of all why do you have zero toe in the rear? Don't you want high speed stability? You should have zero toe in the front if you want more turn in.
You talk about tread depth but what are the condition of the tires? They could be done in terms of being heat cycled if you have romped on them a lot or bought them used. For instance, RS3 are supposed to be pretty sticky tires. Mine are definitely heat soaked. I have some tread left but just spun the tires driving out of my driveway at 5 mph aka they are just super hard and slippery.
12-08-2015, 04:27 PM | #18 |
3431
Rep 6,771
Drives: 2016 BMW i8
I think I mentioned my RS3 issue. I couldn't get any straight line traction (spun up through 4th) and neither could MRF on their 400 wheel NA M3. Lateral grip is terrific, particularly when warm, but there isn't a worse tire for straight line grip than RS3's. No idea why.
12-08-2015, 04:32 PM | #19 | |
3221
Rep 6,218
But my tires are blue from overheating. Drifting. Yes.
12-08-2015, 04:47 PM | #20 | ||||
612
Rep 1,326
hope not! i haven't had any codes pop up regarding the TC module. Quote:
i don't romp on my tires often and i haven't tracked with them, so i doubt they are heat soaked. i'm going to go with PSS next - never tried them so i'm hoping they will solve most of my issues. appreciate everyone's input and insight into this issue!
12-08-2015, 05:18 PM | #21 |
3431
Rep 6,771
Drives: 2016 BMW i8
Haha never heard of them turning blue that's insane. But I'm not a drifter...my car can't do that although I am going to the Thermal Club tomorrow. 5 of us get the entire track by ourselves all day
chief208.00 |
12-08-2015, 06:43 PM | #22 |
3221
Rep 6,218
um where was my invite?
