12-04-2015, 08:18 PM | #1 |
103
Rep 660
@#$%#! fuel door won't shut
Has anyone run into this issue before? Looks like I have a trip to stealership in my near future.
TiAg | ZCP | DCT | Euro MDM | aFe filter | MS Pulley | Akra Slip-on | MS Spacers | 255/275 M4S | H8 180s
12-04-2015, 08:24 PM | #2 |
1258
Rep 2,492
Try pulling the emergency fuel door release (green handle) in your trunk. Should be located above the battery coming through the liner. Maybe that will loosen up the latch to allow it to close.
12-04-2015, 08:25 PM | #3 |
3274
Rep 6,723
Similar to this?
http://www.m3post.com/forums/showthread.php?t=1024023 |
12-04-2015, 08:35 PM | #4 | |
103
Rep 660
12-04-2015, 09:04 PM | #6 |
3274
Rep 6,723
Sounds like something is bent inside. Tension is causing the door to pop open when you unlock the car.
12-04-2015, 09:04 PM | #7 |
103
Rep 660
bro, I don't think you're following along.
12-05-2015, 07:54 AM | #9 |
413
Rep 1,178
Then some idiot obviously forgot to close it, locked the car and then bent some metal trying to force it close while the car was locked. Now it won't shut with the damage.
Sounds about right ? |
12-05-2015, 08:41 AM | #10 |
915
Rep 3,456
Drives: Harrop E90 M3
If the ejector won't stay in the retracted position, it probably just needs to be be replaced. It's a simple fix that you can easily diy. They are replaced from the outside quickly and easily.
12-05-2015, 04:00 PM | #11 |
103
Rep 660
official diagnosis: ejector (519590) broken - removed and replaced.
20 dollar part, 100 dollars in labor - ugh.
12-05-2015, 04:49 PM | #13 | |
103
Rep 660
I just don't have time to dick around with this sort of thing, esp over 100 bucks.
12-09-2015, 08:25 AM | #14 |
Enginerd
118
Rep 542
But you have time to spend on a forum asking for help? Not trying to be a jackass but the 5 minutes I spent replacing my dead fuel latch was much quicker than wasting 1-2 hours at the dealership.
2008 E92 AW 6MT /// 120k orig rod bearings
12-09-2015, 10:10 AM | #15 | |
103
Rep 660
(1) I didn't know the part number until BMW told me what it was; (2) I didn't have to order / wait for shipping, as BMW had it on site; (3) I didn't have to figure how to install it, as the BMW mechanic already knew how to do it. Get it?
12-09-2015, 08:21 PM | #16 |
Enginerd
118
Rep 542
Just saying you asked a question seeking help, someone posted the answer a mere 7 min later, and you still ran to the dealership and waited for the fix.
12-09-2015, 08:48 PM | #17 | |
248
Rep 2,513
12-09-2015, 10:18 PM | #18 | |
103
Rep 660
Review answers -- what guidance did they provide? Man, who let the riff raff in. Reading comprehension challenges abound here.
12-09-2015, 11:06 PM | #19 | |||
3274
Rep 6,723
Let the man be... it's his money. |
12-10-2015, 03:24 PM | #20 |
36
Rep 176
12-10-2015, 03:44 PM | #21 |
337
Rep 1,489
I had this problem and I am trying to recall from memory how I fixed it.
1. That button thing was the first problem 2. The actuator became the second problem. The actuator pushes the plastic stem into the slot to lock the door shut. The gas attendant broke mine. I replaced 1. above. It costed $15 from the dealer. You pull it out from the front and push the new on in. No need for trunk access. The actuator mentioned in 2 above requires trunk access. I did not bother. No one knows it isn't locked shut. |
