12-02-2015, 12:01 PM | #1 |
40
Rep 19
How to correctly read a dyno graph (F10 M5 graph shown))
Hello everyone, my name is Dan Connor. Happy to be a new member of this forum group. I have been seeing a lot of misleading post's of dyno graphs with inflated numbers. In case some of you do not know that it is possible to do this I am going to share how it is done. The purpose of this post is so we can all be more accurate as a community when comparing results.
Before I begin I am aware every dyno reads different. The main area we are looking at is how the numbers are displayed in the scale selected for the graph. The are 2 main scalars which are SAE and STD. The second part is smoothing factor which is normally 0-5. SAE (Standard of Automotive Engineer's) is the closest to manufacture spec. It will generally be a lower number. This calculation takes into consideration outside air temp, humidity and altitude just to name few. All these play a key factory in air density which is key in making horsepower/tq. STD (Standard) numbers are the least accurate and most inflated. This is the graph that I have been seeing the most. This calculation also takes into consideration outside air temp, humidity and altitude. However it uses a higher level of air density will which nets a higher and less accurate number. To compare our results accurately we need to show SAE numbers. The people running the dyno know about this. The reason they show STD numbers are to make you feel better about the money being spent. They know the car is most likely not going to be used in a competition environment and the number will not be questioned. Lastly the is the smoothing factor. This is what what it sounds like. It smooths out the peaks and ripples in the graph. When this is set low i.e. 1 or 0 you are being shown a false number off of a spike in the graph. So to sum it up for all of us to accurately compare dyno numbers we should all ask for and post our graphs in SAE and smoothing factor of 5. Below is a dyno pull on a 2015 Comp package F10 M5 with a flash tune, catless downpipes, stock exhaust, meth kit and 93 octane. The 3 graphs show below are all from the same dyno pull scaled 3 different ways. The 1st graph is shown in SAE (most accurate). The second graph is shown in STD. Horsepower/TQ The 3rd graph is shown in STD with smoothing of 0. This shows how the ripple/spike in the graph can raise the peak number. Hope this helps everyone and thanks for reading. Dan Last edited by Dan@BPC; 12-02-2015 at 04:08 PM.. |
12-02-2015, 01:50 PM | #2 |
Rep 214
I'm glad this was posted.. I was always looking at all the glory dyno runs being posted. wanting to sell my e46 m3.. After talking to my tuner Mike@ maximum psi. I realized that on paper, my car was making the same or more power as the cars I was comparing to..
if you don't mind I will like to post this on other forums if you haven't already |
12-02-2015, 01:58 PM | #3 |
16
Rep 61
This is actually wrong information Dan. Majority of the time BOTH SAE and STD are Corrected values. SAE is corrected to lower atmospheric conditions then STD.
STD: Air Temperature: 60F Absolute Pressure: 29.92 inches Hg Relative Humidity: 0% SAE: Air Temperature: 77F Absolute Pressure: 29.23 inches Hg Relative Humidity: 0% Either one of these methods can also be Uncorrected, meaning on this given day at these current conditions this is what u got. To go from corrected SAE to STD is about a 4% loss. |
12-02-2015, 02:50 PM | #4 |
170
Rep 687
Not hijacking the thread but this is so similar to the false power rating of audio amplifiers.
Meaning the RMS (route mean square) value is much lower and the real power which is not as glorious as everyone wants. For example 100 watts RMS is really like 250 watts peak to peak which means nothing but to the consumer buying it, they love those high numbers. Rule of thumb, amplifiers are 60-70% efficient and cannot make power than they consume. So the next time you see an amplifier with a higher rating on the output than the power consumption just remember this post and its false advertising. To determine the power consumption in, multiply the supply voltage times the maximum fuse rating on the amp, unless its written on it, and thats your power consumption in Watts. |
12-02-2015, 02:58 PM | #5 | ||
40
Rep 19
12-02-2015, 03:49 PM | #6 | |
16
Rep 61
12-02-2015, 03:59 PM | #7 | |
40
Rep 19
12-02-2015, 04:06 PM | #8 |
21131
Rep 20,742
Drives: 2021 911 turbo
I do not fully agree with your post. Since modern turbo engines adapt to atmospheric conditions, using correction factors will skew the result. So it is not correct to say STD or SAE are the more accurate number for these engines. IMO, the uncorrected data is probably the most accurate one. I have read that the SAE and EU regulation even specifiy that for turbo engines that have compensation mechanisms, uncorrected numbers are to be used for the official power ratings.
The fundamental purpose of correction factors is to baseline the numbers so they can be compared to each other. In essence, for the same engine tested in different atmospheric conditions to show the same results. If correction factors are applied to the result of an engine that compensates atmospheric conditions, it will show varying results. Which defeats the purpose.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 12-02-2015 at 08:32 PM.. |
12-02-2015, 04:28 PM | #9 | ||
40
Rep 19
12-02-2015, 07:43 PM | #10 | ||
21131
Rep 20,742
Chassis dynos are good for comparative measurement though. Test before and after mods in similar conditions, and you will get a decent appreciation of the relative gains provided by the mods. Use uncorrected, STD or SAE, it does not matter, as long as you use the same correction for the before and after runs and that the runs were done in similar conditions. Quote:
BTW, even the SAE standards specify that for engines that compensate for atmospheric conditions, no correction factor should be applied. See paragraph 5.5.2 below (thanks to dmnc02 for the reference). So anyone applying correction factors to engines that compensate for atmospheric conditions is NOT respecting SAE standards .
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 02-04-2016 at 01:54 PM.. |
12-02-2015, 10:02 PM | #11 |
363
Rep 1,805
Drives: 2014 BMW M5 F10 CP
We get your points.. Butt Dyno for me is best though.
Where possible I try to be consistent in using the same Dyno for all my testing and for comparison purposes.
2014 BMW F10 M5 ZCP | SSII / Black | MSR Stage III | MSR Intakes | RPi GTM Exhaust | RPi Catless Downpipes |RW Carbon Front Lip | RW Carbon Diffuser | RW Carbon Trunk Spoiler |
12-03-2015, 07:24 AM | #12 |
40
Rep 19
If we refer back to the 3 graphs that were in the first post. They show how with the click of a scaling button you can turn a 676hp/625tq car into a 700hp/655tq car.
We spend a considerable amount of money on exhaust, intakes, flash tunes, piggy backs, turbos ect.. Period bottom line, us as a community need to post SAE numbers with the smoothing factor turned up at or near 5. Without doing this we are not accurately comparing gains. There is no argument or debate. SAE will always be the most accurate. The only reason to post standard numbers with the smoothing factor turned down is to make someone's product show the highest number possible so that you will buy it over the other guys. BMW's are amazing cars! We know this and that is why we drive them. If we want to give ourselves the rep of being the best most educated/knowledgeable group of car enthusiasts out there we all need to get on the same page. |
12-03-2015, 11:53 AM | #13 | |
21131
Rep 20,742
From that perspective, it does not really matter what correction factor is being used, SAE is not any more accurate. What is important is to use the same correction method for the before and after runs. I agree about the smoothing though, spikes need to be removed. But the values for the entire curve are far more telling than the single peak value.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 12-04-2015 at 01:53 PM.. |
12-03-2015, 06:06 PM | #14 |
249
Rep 2,202
Might you care to also enlighten some of our Dynojet friends that their are much lower reading dynos like mustang ones, and that having the higher numbers isn't always a good thing
12-03-2015, 07:51 PM | #15 |
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1092
Rep 1,968
Dyno's are a relative measure to tune the car - take it to the track or do some VBOX runs. There were cars making similar (or more) power running 10mph less in the 1/2 mile. Go figure!
12-05-2015, 07:47 AM | #16 |
363
Rep 1,805
That's my point.
12-05-2015, 09:00 AM | #17 |
1092
Rep 1,968
Also, I think we should start posting the drf file or all the relevant dyno parameters including correction factors etc. It is easy to manipulate otherwise!
12-06-2015, 07:11 AM | #18 | |
1722
Rep 5,110
If using SAE or STD corrections when comparing before and after on a modern turbo engine you MUST have the exact same atmospheric conditions! As you stated (and which was debated in detail on the F8x forums a year or two ago) these modern engines self correct for atmospheric conditions. Adding dyno correction on top of that constitutes a "double dipping" of correction factors. So if the atmospheric conditions have changed on the "after" run (often taken later in the day) the ECU/DME will auto correct boost, timing and fuel for this. But if you use dyno correction for SAE and STD the correction factors will be different between the "before" and "after" runs and thereby skewing the dyno graph between the two runs. On a NA engine the correction factors is there just because of this, to make the end graph comparable even though atmospheric conditions have changed. On a modern turbocharged engine, using these correction factors makes the end dyno graphs void! European magazines like Sport Auto is now publishing their dyno numbers on turbo engines without correction factors just because of this. So DO NOT use any correction factors when dynoing modern turbo engines!!! It will just make the dyno graphs inconsistent and NOT comparable! And then we could also open the debate on dyno inconsistencies, both between different brands of dynos and the strange situation of "low reading" and "high reading" dynojets... Comparison between different dynos is allmost impossible to do with any credibility. Dynos like these are best used to compare a delta gain on before and after runs on the same dyno. |
12-06-2015, 05:14 PM | #19 |
165
Rep 402
I have a modded M6 and I love the car, but I have never seen a platform make so much claimed power and go so "slow" My old v10 M6 went 11.81@ 121 with 508whp and those cars made no tq. These new cars I have seen with literally 200whp more and 300wtq more and not get out of the 11's and not go 130!
12-07-2015, 09:13 AM | #21 | |
1722
Rep 5,110
Problem was that many of them went bad after a few pages and the mods closed a few of them after a certain tuner name was talked about (that also happened to be a forum sponsor at the time...) The OP is a good starting point, but unfortunately has some wrong conclusions... |
12-08-2015, 05:59 PM | #22 | |
249
Rep 2,202
Personally someone could post m6 made 7909090whp tomorrow. It'll mean nothing to me till it sets some records. |
