12-01-2015, 06:12 PM | #1 |
105
Rep 259
What Quick Detailer do you use on your ceramic coating? (Opticoat, CQuartz, etc)
What's everyone using as QD for those who got coatings on their car?
Here's my experience: Since opticoat plus was applied on my car, my normal go to QD was producing streaky finishes (Meguiar's Ultimate QD). I was told by my Detailer that I don't need it, but found I needed something to touch up water spots since I have very hard water. I tried Optimum Instant Detailer and Gloss Enhancer and Sonax Brilliant Shine detailer. Both were better than Meguiar's - but still had issues with streaking or having slight hazing. From what I read, the coating does not like additional layers and will not readily bond with the surface. After reading more into the coating, I read a suggestion that using the Optimum No Rinse as a QD does the trick. It's basically a stronger solution than what you would use for a wash. Results? The ONR QD produced a better shine and gloss. The surface also seems attract less dust. The other QDs would attract dust after 1 day in the garage and seem to stick. After 1 day with ONR, the dust was less and what was there would blow right off. It took me a while to figure this out, so I thought I would share. What's a detailing thread without a picture right after a good wash?
2016 BSM M4 - BBS FI-R, Hex tune stage 2, JRZ RS1, DP/CP/Intake/exhaust
Follow me on Instagram @qs_m4 |
12-01-2015, 06:19 PM | #2 |
748
Rep 1,478
I use Adam's quick detailer - no issues as yet with streaking, great stuff!
Individual M4 Convertible ED Sept 2014
12-01-2015, 06:38 PM | #3 |
687
Rep 2,770
What about CQ Reload: http://www.autogeek.net/cquartz-reload-spray.html
It says it removed water spots and also applies a little additional ceramic coating.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
12-01-2015, 07:00 PM | #4 | |
1108
Rep 1,497
Just to be safe, I'd suggest that if your car is coated with something other than CQ, I'd check to see if you can use Reload on it. |
12-01-2015, 07:37 PM | #5 |
229
Rep 307
I've been using Adam's Detail spray prior to getting CQ done. Corey at Carpro-us said the Adam's should be fine on CQ, but also mentioned they had good results with Ultima waterless wash.
I'm planning on sticking with Adam's for now. Will wash with Reset and use Reload periodically. |
12-01-2015, 07:59 PM | #6 |
Ninja
390
Rep 4,014
12-01-2015, 10:49 PM | #7 |
74
Rep 398
Not all QD are created equal, some will leave a light haze, some won't. Just buff with a clean microfiber towel after applying.
I have been using Meguaiars last touch with great results and after diluting with destiled water a gallon goes a long way. Not need to overpay for Adam's . http://www.amazon.com/Meguiars-D1550.../dp/B0006SH4NC
02-12-2017, 06:32 PM | #8 |
BimmerPost Supporting Vendor
1997
Rep 6,916
we have not used the Kenotek Showroom Shine on coatings for the last year and it's incredible stuff.
give this one a go if you haven't already. |
02-20-2017, 09:22 PM | #10 |
wannabe
252
Rep 819
my f80 is cquartz'd and ive used a few different qd's on it, and Id have to say the kenotek is the best of the bunch, no streaking or hazing.
E90 M3 - 6speed - slicktop - single hump
02-22-2017, 09:01 AM | #11 |
1997
Rep 6,916
I would second that one Kenotek Showroom Shine is what we have used on just about every coating and it is a wonderful product!
02-22-2017, 01:02 PM | #13 | |
589
Rep 1,094
03-17-2017, 11:58 AM | #14 |
149
Rep 92
I have been using Griot's Garage Speed Shine for a couple of years on both light and dark paints and am very pleased with the results every time. Leaves a smooth as glass finish with no hazing. Actually works good on the glass too.
03-17-2017, 12:05 PM | #15 |
293
Rep 546
Use reload with CQ
use liquid crystal with Gtechnique use M2blast with Modesta use cure with Gyeon If your coating company has a maintenance spray, its probably for a good reason. Use what they suggest. Not all products are compatible with different manufactures of coatings as the chemical make up is different. (unless its a relabeled brand) Biggest part to no streaks will be your towel. Get/use quality towels only. |
03-27-2017, 07:21 PM | #16 |
1107
Rep 1,302
ECH2o Concentrate, from the people who make Cquartz:
https://www.carpro-us.com/latest-pro...te-17oz-500ml/ Honestly, this stuff is awesome. Works great as a waterless wash (I was always afraid to do this, but I took the plunge with this stuff and was quite impressed). And of course it plays completely nice with Cquartz, HydrO2, etc. Trust me, you won't be disappointed |
03-28-2017, 06:40 AM | #17 | |
80
Rep 257
Detail spray on coating
This is why it is recommended to use the coating manufacturer's detail/maintenance spray. Bruce |
04-05-2017, 06:07 PM | #18 |
29
Rep 81
I just used PolishAngel Glasscoat Cosmic Spritz on a BSM and all I can say is WOW. I've used many high quality products and this one stands out beyond anything I tried in the last 7 years. Check this stuff out!!
04-06-2017, 08:57 AM | #20 |
1593
Rep 3,945
Drives: 2015 M4 MG/SO
I've used many of the ones mentioned here, and nothing helps with dust... I'll try the OP's recommendation as I never used ONR.
But after much experience, the best QD is a bubble wrap for the car |
