11-28-2015, 02:14 AM | #1 |
997.1TT
1003
Rep 1,672
Jack for M3?
Just wondering what people recommend for a low profile, extended jack to reach under the front of the M3 to the jack point (as well as in the back under the diff)? I have a low profile jack already, but the problem is it isn't long enough to reach all the way under to the front jack point without first jacking up the front corner and putting the wheel down on some blocks/bricks.
Can someone recommend a jack that is both low enough, and long enough to reach all the way under the M3 while it sits on the ground?
Current: 2007 Porsche 911 Turbo Former: ESS Supercharged ///M3 Interlagos Blue ZCP Subscribe to YouTube: https://www.youtube.com/c/Rat3dM Follow me on Instagram: https://www.instagram.com/rat3d_m/ |
11-28-2015, 02:54 AM | #2 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
Honestly I've given up on trying to do it at that front point, for largely the same reason. I just do the front by raising the rear side jack points.
The rear jacking point behind the diff is easy; you can get to easily, I just have the problem where the jack won't raise high enough to get any meaningful height without having to add a large rubber block. |
11-28-2015, 07:01 AM | #3 |
5234
Rep 10,616
Maybe one of the low profile long reach Arcan or Torin jacks.
You can also get there with two small lightweight Harbor Freight aluminum jacks that go for $59 with coupon or on sale. One lifts a side jack point enough for the other to go under the center. |
11-28-2015, 07:46 AM | #4 | |
997.1TT
1003
Rep 1,672
http://www.amazon.com/Sunex-6602LP-L...ile+jack&psc=1 I was thinking something like that, but I don't want to drop $200+ on a jack and find I am in the same boat as I am right now.
11-28-2015, 09:10 AM | #5 |
Rep 55
I used this from Costco: Arcan
http://costcocouple.com/wp-content/u...k-Costco-2.jpg There's no link on the Costco site, but plenty in store. Works great! |
11-28-2015, 10:49 AM | #6 | |
289
Rep 1,536
11-28-2015, 12:57 PM | #8 | |
997.1TT
1003
Rep 1,672
My jack is kind of old and I think it's time to update anyways, so I may as well get one that works. Ill still keep it but I do want a nicer jack if there is one that works with the M3 jacking points.
Krypt0nite0.00 |
11-28-2015, 01:57 PM | #9 |
11817
Rep 23,187
You can make anything work. I have old massive craftsman with big deep top that just goes around the jack points or put a hunk of wood or floor Matt on it for other lift points. Then I have the standard harbor freight aluminum for at the track. Also have ezcarlift that get used all the time.
11-28-2015, 02:16 PM | #10 |
59
Rep 1,036
http://m.harborfreight.com/3-ton-low-profile-steel-heavy-duty-floor-jack-with-rapid-pump-61282.html
Bought it for $80 with coupon. Well worth it. |
11-28-2015, 05:01 PM | #11 |
83
Rep 468
Some other folks have recommended this one, but I have not used it yet. Am thinking of giving it a try, but would be nice to hear from someone that has it.
http://www.amazon.com/dp/B000RFUETA/...I10Z3S198IFPPP |
11-28-2015, 07:59 PM | #12 | |
75
Rep 903
Drives: E90
2011 E90 M3 6mt AW/Speed Cloth - ZCP, Moonroof, non-iDrive - PCD 12/9/10 Painted reflectors, matte black grills/gills, Deansbimmer Belly Pan, DEI Alarm, Homelink/compass retrofit, Passport MAX2 Hardwire, GP Thunder 8500K, modmy3 LED interior, Dinan Mufflers, HRE P40 19" Satin Charcoal, Michelin PS4S |
11-29-2015, 04:42 AM | #13 |
5234
Rep 10,616
For those not getting the height they want with a small jack in order to fit jackstands, do the obvious. Try a block on top of the jack or get a jack with a few more inches lift height. I think lift height varies by as much as about 6 inches from 1.5 to 3 ton jacks.
11-29-2015, 06:49 AM | #14 | |
997.1TT
1003
Rep 1,672
11-29-2015, 10:13 AM | #16 |
289
Rep 1,536
11-29-2015, 01:25 PM | #17 | |
997.1TT
1003
Rep 1,672
http://www.amazon.com/gp/aw/d/B00L1ZCN0I/ref=pd_aw_sim_sbs_263_1?ie=UTF8&dpID=41tRlE0MmZL&d pSrc=sims&preST=_AC_UL100_SR100%2C67_&refRID=17ET6 31XAKHG652P8BPX |
11-29-2015, 04:59 PM | #18 |
594
Rep 4,488
I use the OTC 1532 jack (the 1533 kit includes stands) but I never go for the center jack point. I just got a pair of ECS Tuning jack pad adapters and go from the side. The few times I've needed the whole front end up at the same time I got my hands on another jack and at least had the second adapter handy.
AC Hydraulics makes a very long low profile jack but it is neither portable nor inexpensive.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
11-29-2015, 09:47 PM | #19 |
32
Rep 47
Drives: 2010 e90 M3, 2006 BMW 330xi
I picked this one up today on the recommendation of my friend that has one for his M5.
http://www.harborfreight.com/2-ton-l...ump-60678.html Raises to 24" and can reach far enough under the car to hit the center jack point. Got it for $120.00 |
11-30-2015, 05:28 PM | #20 |
14
Rep 198
After going through a few Craftsman jacks, I use an AC Hydraulics which I picked up when I had my Z06. They're not cheap, but it gets the job done and should last most of my lifetime.
12-03-2015, 12:05 PM | #21 | |
103
Rep 893
