11-24-2015, 08:38 AM | #1 |
134
Rep 170
Service recommendations: Used car unknown history
I recently gambled on a super clean 2010 135i with 48k miles. It was such a good deal, I forewent the requisite visit to my mechanic to have it checked out. Other than a low battery (which I am addressing today) it seems to be a solid car.
At 48k miles I am thinking its due the regular services at least (oil, brake fluid & filters), but imagine its probably due new plugs. I called the BMW dealer in the city that the car was bought and the last service record they have was routine service (oil, brake fluid & filters) at 27k miles. I looked at the air filter last night and it is brand new but not a BMW filter, which tells me the car has been serviced someplace. The in car service indicators are only showing the routine stuff which is due. I have yet to get an appointment with my independent to have him do a run through of the car, which will probably tell me more. I obviously want to do a software update, the fluids and if I can't determine if the plugs have been changed will do that.... What else should I be considering doing on a car I'm uncertain of its history since the 27k? Transmission Flush? Dif? Radiator? I know these cars are suppose to be good for 100k miles but despite the expense, I'd feel better knowing what has and has not been done. |
11-24-2015, 10:16 AM | #2 | |
4338
Rep 6,196
12-14-2015, 11:35 PM | #3 |
1542
Rep 3,071
Oil change + check everything else.
I just picked up a really clean 2011 135i. I got lucky and the maint. Slips we're in the glove box. .
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
12-17-2015, 09:16 PM | #4 |
191
Rep 506
Drives: 2010 128i 6MT Sport Pkg. 18"
Not a bad time to do all the fluids. That's the life of your car. Then you'll know exactly where you are and at 48k. it's a good time. Like you said, oil, coolant, brake fluid, Trans.(assuming it's a manual), Differential, also often overlooked power steering fluid. If I've overlooked something, change that too. Fresh fluids are the best way to protect your investment.
12-17-2015, 11:05 PM | #5 |
1542
Rep 3,071
Here's my maint. Sched
Oil and filter: 5k to 7k mi. (max) Air filter: 2 yrs or 4th oil change Brake fluid: every 2 years Coolant flush: every 2 years Power steering fluid: 3 yrs Cabin air filter: 3 yrs or 30k mi. Differential: 30k miles Walnut Blast: 50k (w/ catch can 90k) Belts: 5 yrs or 50k mi. Water pump: 5 yrs or 50k Spark plugs: 60k mi. Trans. flush/fill: 60k mi. Fuel filter: 60k? (in fuel tank) |
01-16-2016, 03:05 AM | #6 |
55
Rep 156
Drives: 2010 e82 n52
I would not worry about the plugs at 48000 as it's not an n54 and the plugs are rated at 100,000 on the 128...that being said, after I hit 100,000 I had a very slight miss and new plugs resolved the issue. NGK BMW stamped or not will be fine but don't use Bosch unless they're from the dealership.
01-16-2016, 04:09 AM | #7 |
1542
Rep 3,071
I believe the plugs are every 45k on the n54 (and n55 if tuned).
