11-20-2015, 10:18 PM | #1 |
21
Rep 182
Dyno results... Normal?
What do you guys think about these results on a dynojet? My car has a vf620 kit and test pipes. My friends car is bone stock. Looks like both of us are loosing a lot of power due to the altitude...
11-21-2015, 02:36 AM | #2 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
What is the altitude?
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
11-21-2015, 06:22 AM | #3 |
5234
Rep 10,616
SLC is 4300. That would explain about 13% loss. But dynojet can be run with altitude correction. Question is whether the shop was using it.
11-21-2015, 08:27 AM | #4 | |
997.1TT
1004
Rep 1,672
I think the numbers seem very low. It should be closer to 351 whp based on the 15% rule. Of course, this is just my opinion. What do I know? At least the 620 SC setup is showing better numbers on the same dyno (78% drivetrain loss opposed to the OEM S65's 73% loss.)
Current: 2007 Porsche 911 Turbo Former: ESS Supercharged ///M3 Interlagos Blue ZCP Subscribe to YouTube: https://www.youtube.com/c/Rat3dM Follow me on Instagram: https://www.instagram.com/rat3d_m/ Last edited by Rat3d ///M; 11-21-2015 at 08:34 AM.. |
11-21-2015, 01:53 PM | #5 |
334
Rep 1,991
The dyno numbers on your buddy's car seem pretty low, I remember the numbers on my first e90 M3, all stock was around 335 hp and 230 torque to the wheels...
11-22-2015, 02:25 PM | #6 |
Rep 91
I am the owner of the kind of stock e90 that dyno'd with (OP) Europower. The car does have 20" Vossen Wheels which I have heard could contribute to power losses at the wheels.
My thoughts on the Dyno results were also that it seemed low. Curious why? Wheels? Altitude? Mechanical? Software? |
11-24-2015, 03:45 PM | #7 |
29
Rep 156
Seems very low but then again many things can be factored in. My car only made 352whp & 259 wtq (dyno jet) with Grupple m intake, tuner test pipes, Gintani race exhaust & Bpm stage 2 tune.
Gintani Stage 2.5, Gintani Race exhaust, Gintani x-pipe, Stack Gauges, M performance spoiler- Wheel- Mirror caps, KW V3, Mode Carbon GT4 & LM , HRE R40. 580Whp & 380Wtq
11-24-2015, 04:06 PM | #8 |
3431
Rep 6,771
Drives: 2016 BMW i8
4,200 feet? Well then these results seem normal. You are both losing maybe 10 hp per thousand feet so add that back and the stock one is making 340 and the blown one 530. There you go.
12-14-2015, 10:55 PM | #10 |
Rep 36
Those appear to be corrected numbers as indicated by the SAE 1.13 (13% correction factor). Real rwhp should be much lower than that especially for the NA car.
12-15-2015, 07:19 AM | #11 | |
303
Rep 1,140
Drives: Something something racecar
12-15-2015, 08:04 AM | #13 |
222
Rep 1,632
350whp seem low since most people have seen around 330-340whp when stock !! i have a similar set-up as yours with the addition of MS Pulleys and my tuner told me that i should expect around 480-490hp to the crank which mean's around 400whp ...
12-15-2015, 10:27 AM | #14 |
Rep 40
12-15-2015, 11:09 AM | #15 |
5234
Rep 10,616
That is what your tuner told you. Go get on a Dynojet.
12-15-2015, 11:40 AM | #16 | |
689
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
12-15-2015, 12:27 PM | #17 |
413
Rep 1,178
wow significantly bad result. It seems the e92 m3 is an underperformer does not meet the manufacturer specs. Each time i see a dyno post people complain it's worse than expected.
What gas did you pump ? |
12-15-2015, 01:27 PM | #18 |
550
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
There are a number of factors at play here, and fuel is but one of them. The M3 generates a maximum of 414 bhp (420 using European measurements) at the crank. There is a loss of power between the crank and the rear wheels in every car, and this has to be factored in. Secondly, maximum power is generated at 8,300 rpm. The first set of graphs shows road speed, but not engine speed. Below 8,300 rpm you aren't generating full power. Third is the condition of the engine. Up to around 40,000 miles you should anticipate no power loss, but beyond that the wear to components like cylinders, piston rings, valves, and seals can and does have an impact on power production. This isn't unique to the M3. Finally, aftermarket "enhancements" often promise improved performance but can deliver the opposite (and some really do, but that's another subject).
12-15-2015, 04:09 PM | #19 |
5234
Rep 10,616
That is one reason to go to the dyno or dragstrip -- to see how your car is performing relative to other cars, whether your car is stock or modified. I plan to take my 08M3, out of curiosity. I take my turbo 99M3 every year or two -- did 677/580 on a Dynojet in SAE recently. My 08M3 has all the bolt ons and I figure it will do 375-400 rwhp with about 275 lbs rwtq, but the proof is in the plot and I don't have one yet.
12-15-2015, 07:01 PM | #20 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
460
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
I got 363 whp with tune and test pipes. 2nd run.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
12-15-2015, 07:05 PM | #21 | |
1518
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
12-15-2015, 07:09 PM | #22 |
1518
Rep 4,744
I think a lot of time people just simply put too much faith in dyno numbers. Its really impressive to drive in canyons or track, even in stock form but its not a dragstrip / dyno car.
