11-20-2015, 02:09 PM | #1 |
Joint Chiefs of Staff
4923
Rep 115,999
JB4 s63tu world record @ 770whp /830wtq
Saw this and thought it would be of interest to the group!
The test car (BMS Owned) has a JB4, BCM, BMS intake, BMS chargepipes, BMS methanol (dual CM7 nozzles, spraying 100% Meth), Dodson clutch packs, and around 95 octane fuel. Half and half 100 with 91, factory turbos, factory exhaust system including all emissions equipment, factory rims/tires, etc. The mods can be installed and removed in literally an hour or so. Notes from the Run 1) Pushed boost up to 30psi to get power up to 770whp. What's interesting is that the JB4 monitors boost in both banks, while the passenger side bank produced 30psi the driver side bank running the same duty cycle produced only 27psi. If both banks could get up to 30psi we might see 800whp stock turbos and exhaust! 2) With the dual CM7 on 100% meth the car is still fuel limited. Trims maxed out around 28psi so larger nozzles my be in order. 3) The BMS s63tu intake seems to be worth around 15whp peak at this boost level. |
11-20-2015, 02:19 PM | #2 |
206
Rep 1,250
Drives: 20' X3M CP
Why did Terry take off the downpipes on is car?
I thought he had the ER Dp's. Unless of course this isn't his car.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
11-20-2015, 02:41 PM | #4 |
143
Rep 715
Great numbers! Wonder what it would look like with downpipes?? Stock downpipes have to be holding it back.
2015 M5 - Singapore Grey Metallic - Silverstone Full Merino Interior - Executive Pack - Drivers Assist Pack -Comp Pack -
11-20-2015, 02:55 PM | #5 |
4923
Rep 115,999
11-20-2015, 03:00 PM | #6 | |
4923
Rep 115,999
Mike |
11-20-2015, 03:02 PM | #7 | |
185
Rep 792
