11-19-2015, 04:13 PM | #1 |
Rep 15
UPDATED WITH VIDEO - Diagnose this engine whine noise?
UPDATE: ADDED VIDEO
I just spent a very frustrating 4 hours replacing my 2 tensioner pulleys and belts. I was going to change the idler pulley also but ECStuning sent me the wrong part... Unfortunately, it didn't solve my problem. Can anyone diagnose this whining sound coming from my engine? http://picosong.com/bcX6/ Updated with video above Last edited by fancybmw; 01-18-2016 at 04:11 PM.. Reason: Added video |
11-19-2015, 04:17 PM | #2 |
420
Rep 1,678
Drives: 2011 MCB E92 M3
Is that a link to a virus...
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
11-19-2015, 04:54 PM | #4 |
24
Rep 79
Does the sound get worse when turning the steering wheel? That would point me toward power steering pump. If not maybe the ac compressor and or clutch/bearing or maybe the bearings for the alternator are starting to fail.
11-19-2015, 05:48 PM | #6 |
176
Rep 1,251
Drives: E92 M3
I have that sound too, don't remember it being there before... Its sometimes there and sometimes not there... I never hear it after a hot spirited drive though...
2013 Scion FR-S
2009 BMW E92 M3 2008 BMW E90 335i 2005 BMW X3 3.0i |
11-20-2015, 06:41 AM | #7 | |
Rep 15
It fluctuates with RPM. |
11-20-2015, 02:12 PM | #8 |
103
Rep 999
Maybe you have a supercharger installed and you just don't know it?
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
01-05-2016, 09:29 PM | #10 |
165
Rep 1,402
Drives: 06' E46 M3 ZCP
OP - any updates?
01-07-2016, 04:41 PM | #12 |
31
Rep 132
I've said it before and I'll say it again. u know what bearings I'm talking about , the ones of the rod type.... but in all honesty it's hard to tell but sounds basically normal. I wouldn't worry till it gets worse. If it even does... if there are no knocks or rattles it's likely nothing to worry about too much.
01-11-2016, 07:03 AM | #17 |
156
Rep 509
I get that same noise during a cold start (or at least notice it during a CS). If were referring to the noise as you increase RPM via rev? Sounds healthy to me!
2010 e92 m3 | Apex Arc-8 | Remus Race Exhaust & Macht Schnell Xpipe | KW V2 Clubsport | Carbon Fiber Driveshaft | SPL Suspension Upgrade| BBK F/R | ESS VT2 625 |
Instagram: https://www.instagram.com/boostedtrav_/ Youtube: https://www.youtube.com/boostedtrav |
01-11-2016, 07:42 AM | #18 |
340
Rep 947
I guess yr talking about the "whistle" noise that goes along with the refs, right?
I really don't think it's the engine. Most likely it's something driven by either one of the belts or the belt by itself. One belt is for the alternator and the water pump and the second one is for the AC compressor. Turn off the AC and see if the noise stops. Also each belt have an adjusting pulley. Could be one of them as well. My bet, according to what I can hear, the problem is on one belt or one pulley. Try spraying some belt conditioner on the belts. One at a time. Also spray some oil on each pulley. Also one at a time then check the noise. Good luck |
01-11-2016, 10:47 AM | #19 |
165
Rep 1,402
Here's a video of the noise that I am getting. It comes and goes. This weekend I made a hard right turn, nothing to crazy, and then it started. Can anyone identify it?
01-15-2016, 10:13 AM | #21 |
165
Rep 1,402
01-15-2016, 10:14 AM | #22 |
165
Rep 1,402
Does anyone else experience this? Why is this thread all of a sudden dead?
