11-09-2015, 01:59 PM | #1 |
*_*
808
Rep 3,160
AD08 R do they fit wider?
I am thinking of switching stock 19 tires (Conti 5Ps) with stock fitments 255 - 275 / 35 / 19 AD08 R. I hear AD08 Rs could fit wider, so a 255 is really a 265 and a 275 is a 285.
Hoping someone can chime in to say this is or isn't the case. I'd go 275 (F) and 295 (R), but I'm concerned that A) Yoks are limited to 30s when going that wide and B) the fronts will rub the inner liner (like my E92 did when I uprated to 255s up front). Note, I was lowered on Swifts (1 inch lower), same deal on this M4. Thanks for your thoughts in advance. Last edited by S65V8; 11-09-2015 at 02:05 PM.. |
11-09-2015, 06:14 PM | #2 |
22
Rep 14
This has been the case in my experience. The bead-to-bead is still true to size, but there is a little more meat on the sidewalls. Hope this answers your question.
11-09-2015, 09:50 PM | #3 |
629
Rep 1,753
They should still look pretty flush. The stock PSS rears are stretched from the factory. The fronts might be slightly meatier, but as long as you stick with stock sizes, it shouldn't look weird or bulging
That is the route I am going to go with in the spring.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels) 15' Audi S4 13' Audi TTRS (APR stage 1, MSS springs) 09' C6 Z06 08' M3 Interlagos Blue: 6sp, Tech. |
11-10-2015, 02:14 AM | #4 | |
*_*
808
Rep 3,160
11-10-2015, 07:07 AM | #5 |
721
Rep 2,342
They are just more square at the shoulders and at the end of the tread section.
FWIW, I run 275/30-19 and 305/30-19 on OEM rims. 10mm spacer up front, and lowered and I have no rubbing issues. Ride is as good if not better than MPSS IMO. |
11-10-2015, 07:10 AM | #6 | |
*_*
808
Rep 3,160
11-10-2015, 08:00 AM | #7 |
21117
Rep 20,741
Drives: 2021 911 turbo
See here:
http://f80.bimmerpost.com/forums/sho...highlight=AD08 In /30 profile ratio, but still gives an idea of the width.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
11-10-2015, 11:52 PM | #8 |
The limit of adhesion is my home.
1702
Rep 3,778
Note his sig - he has an F80 M3. The wider tires will naturally not rub because of his bigger wheel wells. Might not be the case for the M4.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
11-11-2015, 03:19 AM | #9 |
*_*
808
Rep 3,160
The F80 and F82 have identical bottom front ends (sans the top greenhouse) where turning lock would / might create rub, it has nothing to do with the rear regarding the issue of rubbing.
12-02-2015, 08:38 PM | #10 |
1702
Rep 3,778
Sans?? Ahh....really? Ulul!
12-03-2015, 08:27 AM | #12 |
132
Rep 370
What's your reason in going to these tires? Traction? I have been thinking Along the same lines as you BUT I have not seen any conclusive qual (mainly user opinion) and or quant showing better traction.
12-03-2015, 01:25 PM | #13 |
629
Rep 1,753
I can't wait to get these tires on my car.
I have no experience with them, but I have a lot of experience with this category of tire, as I have used the RE-11 on 4 different cars now. They make a sports car much more rewarding. As to these tires specifically, I am looking forward to a sharper turn-in, as they are known for being super sharp on initial turn-in. Also looking forward to the increased traction and stiffer sidewalls for greater cornering grip. With how restrictive MDM mode is, I think these tires will do a lot for the fun factor of this car for the summer months. I was planning on doing Euro MDM coding, but think I will wait and get these tires on first and see if the increased grip fixes the issue first. Since we are in an El Nino year here is CA, I will keep the PSS's on until spring.
18? Camaro 2SS 1LE
