11-09-2015, 10:51 AM | #1 |
180
Rep 478
Car hesitating to accelerate in 1st with M button on. Any ideas??
Hey Guys,
Last night I was stopped at a traffic light. The car was in S 5 and I had the power set to Sports plus. I hit the M button. When the light turned green and I hit the gas pedal hard the car started accelrating but then hesitated as though i took the foot off the pedal then accelrated and then off again... The sequence went on till I shifted to 2nd and then it was gone, it happens only in 1st when pushing down on the gas. No codes or anything. I thought it was random but it did the same exact thing at the next traffic light. This happened only with the M button on. Its perfectly fine with the M button off. What could it be? Any one experience this before? Should I get it checked. Forgive me if this is something obvious that I should know but I am not a guy who has extensive mechanical knowledge about cars...just getting to learn more about these wonderful M machines so any advise will help. |
11-09-2015, 12:21 PM | #3 | |
180
Rep 478
I m not sure if I should try to replicate it at the dealer and have it checked out or is it something normal that happens when I was trying to floor with the M button on. Any other thoughts? |
11-09-2015, 01:19 PM | #4 |
18
Rep 97
I would suggest doing it with traction control completely off but I would be very careful if you did and make sure your in an empty lot. This will let your tires spin without dsc or mdm interfering. Meaning no cutting off power.
If it still happen you can take it in. Remember that in 1st gearthe pedal is really sensitive too so that might also be why. I'm sure someone else will come in shortly. |
11-09-2015, 02:42 PM | #5 | |
16
Rep 56
11-09-2015, 06:04 PM | #6 |
4985
Rep 11,891
Need moar traction yo!
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) Last edited by Flying Ace; 11-12-2015 at 01:53 PM.. |
11-12-2015, 02:18 PM | #8 |
550
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
11-12-2015, 03:23 PM | #9 |
368
Rep 1,198
Drives: 2021 F87 M2c. LBB, 6mt
were you on a bumpy road? With M mode on the accelerator is very sensitive. IF you are going over bumps, your foot could be moving thus decreasing throttle.
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
11-12-2015, 03:28 PM | #10 |
4985
Rep 11,891
yep, this. And also the car can skip over bumps causing traction issues as well.
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
11-12-2015, 06:39 PM | #11 |
180
Rep 478
No I wasn't on a Bumpy road. Like I said it was very short bursts of accelration followed by drop in power each burst lasting about a fraction of a second...it was that quick. I was jolting vigorrously forward and backward when it happened and then I shift to 2nd and it's normal.
11-13-2015, 01:35 AM | #12 | |
///M3mber
185
Rep 430
Drives: 2008 E92 M3
When you turn off DTC, make sure your EDC is switched to the softest setting for the best grip off the line. Like others have said, if you feel the power cutting in and out when DTC is off, take the car into a shop/dealer.
11-14-2015, 07:59 PM | #13 |
38
Rep 160
It happens to me in 1st gear with M button on when I am gentle with the throttle. It goes away if I shift to second or push the pedal down further. If I am going to be putzing around, M mode is off and I don't have the hesitation.
2013 E92 M3 w/ Competition Package
2020 X3M Competition |
