11-03-2015, 03:35 PM | #1 |
1090
Rep 2,799
Touchless car wash
Does it cause any swirls or paint damage , its a complete touch free system. I used it on my audi a lot and specially helpful in winter and does pretty good job.
Thoughts on using it on the new M?
2021 M2C HS/6MT/Exec/Moonroof
11-03-2015, 03:53 PM | #4 |
2228
Rep 1,897
11-03-2015, 07:09 PM | #5 |
60
Rep 80
Yes. Bear in mind they are using chemicals to clean the paint, so it's stronger than an ordinary car wash. This will adversely impact whatever wax, sealant or other protective coatings you have on the car. Not sure about paint protection films, but the manufacturer should be able to address those questions.
-Raj
2015 M3 Tanzanite/Silverstone, 6MT, LED, Exec, 19" silvers, M Adaptive, HK 2005 A4 Avant Quattro Black/Black, 6MT, other stuff you don't care about |
11-04-2015, 08:37 AM | #6 |
687
Rep 2,770
I used to use one on my e92 335. The chemicals ended up oxidizing some of the shadowline trim so bad it started turning white.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
11-04-2015, 10:38 AM | #7 | |
1090
Rep 2,799
I used the touchless car wash on my audi S4 and there were no issues on the paint and it did a good job in between my hand washes. Normally i hand wash 2-3 months and in between take it to the touchless car wash , would like to hand wash more often and dont have time or weather issues. The M is my DD and not garage queen
11-04-2015, 11:14 AM | #9 | |
687
Rep 2,770
11-04-2015, 11:30 AM | #10 |
1090
Rep 2,799
there are no rails , its a touchless lazor wash.
Ofcourse i dont take my car to car wash with rails, no way
11-04-2015, 11:37 AM | #11 |
433
Rep 914
I would heavily advise against it.
Hand wash only and when it gets too cold... bring it in the garage and use a waterless or rinseless and still hand wash.. Unless you are a fan of scratches on your paint and overly harsh chemicals on your trim etc to get a "quick clean" that still leaves dirt behind.
In all your ways acknowledge Him, And He shall direct your paths.
11-05-2015, 02:09 AM | #12 |
First M Car
Rep 24
I used the chemical guys eco smart few times but be careful to use super clean microfiber towels. you can do your car in about 30 minutes or so. i havent seen any scratches or any other issues but i do polish ,seal and wax every 6 months.
11-05-2015, 09:03 AM | #13 |
228
Rep 287
Drives: '22 X4 M40i / '24 X5 M60i
My PPF installer suggested touchless car wash over regular hand washing to avoid swirl marks.
Hi installed Xpel Ultimate (full front + CF roof) and GTechniq Crystal Serum coating on the car body, including the rims and calipers. When discussing harsh chemical used in touchless car wash, he recommended local Esso station over Shell due to harsher chemical use in the latter. No proof that different chemicals are being used between those two was given . |
11-05-2015, 02:12 PM | #14 | |
2228
Rep 1,897
11-05-2015, 05:46 PM | #15 | |
228
Rep 287
To be honest I am not an expert enough to say that touchless car wash is causing swirls with the coating on. |
11-05-2015, 07:26 PM | #16 |
1593
Rep 3,945
Drives: 2015 M4 MG/SO
So I am going through that dilemma too as winter is approaching, I just redid my garage and to wash the car inside either requires half height ceramics or some curtains... I don't believe in waterless or rinseless, unless you are a super pro with a super technique swirls will be introduced and can inky be used with very lightly dirty car. I think once a month in a touchless car wash system isn't going to do more damage then all the environmental conditions our clear coats are subject to. It would be good though to alternate with a hand wash and maybe re-apply a wax or any other quick topcoat as those chemicals used in the touchless system may strip some protection.
I just washed my car today outside, probably for the last time and I think I will install some bathroom clear curtains in my garage to give my M a shower once in a while to remove all the winter salt, sand and dirt ! |
11-07-2015, 08:22 AM | #17 |
715
Rep 746
I also had a veteran professional detailer tell me the touchless car was is OK and the clear bra guy said the same. Here in Austin these are basically the top guys. Donavin with Above & Beyond detail, and Sunbusters for the PPF. If there's a Ferrari or Lambo, or whatever exotic in town... It goes to these guys. I'm not saying they all drive through the gas station car wash, but I do trust their opinions.
I drove my E90 through the touchless wash (Rudy's on 620 for fellow Austinites) but with my F80 I haven't done it. I'm sure I will when the newness wears off, but for now it's hand wash only. For a fast hand wash, I'm absolutely delighted with the ease and results of the following kit and technique. I washed my car inside my garage while it was pouring rain outside. I thought optimum no rinse was just for wiping down a slightly dirty car, but my car was FILTHY with caked on dirt and road grime from recent rain. The clean bucket stayed completely blue and clear, and the dirty bucket was black with grease and dirt. I shoulda took pictures. Here’s the kit I bought: http://www.detailedimage.com/Pro-Kit...-Wax-Kit-P442/ And here is the technique: http://www.detailedimage.com/Ask-a-P...imum-no-rinse/ So... Long post, but if you're in a rush and don't want to drive through a car wash, you could wash only with the above technique in 20-30 min, and skip the wheels and wax until you have more time. |
M4Heritage0.00 |
11-07-2015, 08:32 AM | #18 | |
1593
Rep 3,945
I am hesitant to do that often because I thought I followed every single tip on earth and one day when the sun was shining inside my garage, I see a nice marring on the rear fender. So need to be careful not only during the wash, but most importantly during the drying stage... Check this AG mega thread from Mike Phillips on the technique you mention. |
11-07-2015, 08:44 AM | #19 | |
2228
Rep 1,897
11-07-2015, 08:48 AM | #20 | |
715
Rep 746
11-07-2015, 08:53 AM | #21 | |
715
Rep 746
But I would have had the same fear about protecting the paint, and now I'm a believer. To each his own - and however you wash your ///M - it's a great time to bond with it. |
11-07-2015, 10:06 AM | #22 | |
1593
Rep 3,945
Back to the original topic, I think once a month touch less car wash is fine for the four winter months in my case, and in between hand wash with pressure gun/foam gun while its -30C outside |
