11-02-2015, 12:19 AM | #1 |
210
Rep 919
UPDATE - BMS stage 1 issues
Just wanted to see if anyone else has had a similar issues. I already searched all the JB4 and stage 1 posts, didn't see this exact issues, hopefully I didn't miss it. So I BMS stage 1 and BMS intakes installed. I live in South Ga and run 93 octane gas.
I have noticed that when I am in 4th (and sometimes 3rd) gear (6MT) when I get around 6500 rpm (+/- 200 rpm) I get this shuddering effect, almost as if the speed limiter is kicking in or its misfiring. No engine code. I shift to the next gear and no issues/power loss. Its really strange and annoying. I originally installed the intakes about 3 weeks prior to the stage 1, MAF is sitting nice and I have none of the rough idle issues that some people have. I have about 3000 miles on the car. I contacted BMS about this, and this was Terry's thoughts "stage 1 does not have fuel control like a JB4 so it can max out the fuel tims in cold weather in some care. Suggest lowering the boost gain from 4 psi to 3 psi or upgrading to a JB4." Anyone else have any thoughts? Anyone with similar issues? I was thinking maybe it could have been bad fuel, but didn't really feel like engine knock, but not sure. I read somewhere in one thread (unrelated to any specific tune) about higher boost and incorrect plug gapping. Could this issue be related? What would I feel in this scenario? Any thoughts/comments would be appreciated. Thanks. PS - I love this car, it really is amazing. EDIT: In regards to sprak plugs read post #18 in this thread http://f80.bimmerpost.com/forums/sho...ght=spark+pugs also this thread ... http://f80.bimmerpost.com/forums/sho...ght=spark+plug post #7 in this thread: http://f80.bimmerpost.com/forums/sho...ght=spark+plug UPDATE - I removed the BMS stage 1 tune and problem is gone. I also noticed that it was happening in 2nd gear as well. Another strange thing I also noticed is that it also had this weird stuttering, kinda like a mini miss fire, around 3000 rpm as well that is now also gone. I am wondering if I got a defective unit. I'm going to contact BMS tomorrow and see what they think. Thanks everyone for the input. UPDATE - issues fixed. Terry and Donnie were both helpful. Donnie thank you for fixing the MacOS software. Terry communicates very fast via email, almost like text. Appreciate the help. I ended up have to drop my boost to 3.5 and fixed the issue. I do like the adjustability of the boost. I actually think I'm going to fun 3.0 for now, until I get wider rubber in the rear, its a little hard to manage right now (don't get me wrong its a blast, just everyone is going to think I'm an a$$hole shaking my rear all over the street.... UPDATE - issue not fixed, dropped the boost to 2.0 and still happening. UPDATE - I swapped back to stock intakes and still the same issue. Kinda stinks, the power from the stage one is great, but I don't like short shifting at 7000 to prevent the problem from happening ( I know the power band drops off, but still, its more fun to rev to redline....) FINAL UPDATE - ISSUES FIXED - Final update because I just realized I never did update this thread I ended up flashing my ECU to the most recent update at BMW and that seems to have solved all my problems. For some reason my stock boost maps were much higher than everyone else's. Not sure why. Basically my car stock was already like map1. So when I went to run any additional map the boost was just too high and I was maxing out my fuel trims, car was insanely fast tho lol, got lucky nothing went wrong, stock DME is good about this obviously.
2018 F80 ZCP 6MT YMB/SO 2015 F82 M4 6MT AW/SO - SOLD Last edited by PayamFSU; 04-07-2017 at 10:42 AM.. |
11-02-2015, 09:23 AM | #3 |
3441
Rep 79,211
He has the BMS intake.
Honestly, I'd recommend going to the JB4 at a minimum. It's a safer tune with more control and won't leave you blind. You'll be able to datalog your vehicle and see how it's performing. |
11-02-2015, 09:30 AM | #4 |
SITH
97
Rep 385
From what I have gathered it seems like the intakes were affecting (or is it effecting?) the start up/idle of things. If you have the time I would take the intakes off and do some pulls and see if the issue remains. If it does then definitely follow Terry's advice and lower the boost (or upgrade to the JB4 if you have the disposable cash). Hopefully you get it figured out.
11-02-2015, 09:31 AM | #5 |
SITH
97
Rep 385
I thought that the JB4 map 1 and the BMS Stage 1 were literally the exact same tune, with the JB4 allowing you to data log/change maps.
11-02-2015, 09:43 AM | #6 | |
3441
Rep 79,211
As you are in your current situation, you have no idea what is wrong. Are you running out of fuel, or is it just your intake? None of us really know. The only way to test would be to put the stock intake on and see what happens. At least with the JB4 it has a USB for datalogging so you can view and look over datalogs and see how your car is running. With those datalogs, you can view sensors and likely come up with what is wrong without removing any hardware. From those datalogs, you can make adjustments in the tune to optimize it as well. That's why I recommend all my customers to consider the JB4 at a minimum. I'm not trying to make a sales pitch here. As an avid enthusiast and tuning guru, I like control and put safety of my engine as number 1. |
11-02-2015, 10:00 AM | #7 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
11-02-2015, 10:14 AM | #8 | |
BimmerPost Supporting Vendor
24273
Rep 190,970
11-03-2015, 12:56 AM | #9 |
210
Rep 919
Thanks to everyone for their input. The only reason I was wondering if something else was going on is because it seems a lot of people have this tune, but haven't heard of these symptoms before was seeing if anyone else had this experience.
Also anyone have any input in regards to incorrect gap plugs? Could the symptoms that I described be related? Just curious.
2018 F80 ZCP 6MT YMB/SO 2015 F82 M4 6MT AW/SO - SOLD |
11-03-2015, 09:46 AM | #10 | |
4920
Rep 115,999
Mike |
11-03-2015, 09:55 AM | #11 | |
3441
Rep 79,211
11-03-2015, 09:59 AM | #13 |
390
Rep 859
Drives: 2017 Alfa Giulia Quadrifoglio
The problems with Burger stuff is not exactly confidence inspiring. Kind of feel like there stuff is beta tested by customers. Personally, I'd rather stay away.
11-03-2015, 10:28 AM | #14 | |
262
Rep 658
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
11-03-2015, 11:10 AM | #15 | |
4920
Rep 115,999
Mike |
11-03-2015, 11:38 AM | #16 |
450
Rep 992
I feel it a little absurd seeing people who has issues with stage 1 being advised to buy a JB4, because people buy stage 1 for a milder, safer and easier install-and-forget tune as it's advertised.
11-03-2015, 12:23 PM | #17 |
142
Rep 555
11-03-2015, 12:30 PM | #19 | |
4920
Rep 115,999
If the purpose is a mild addition to power and easy to install then you are right makes little sense to install jb4 but it's just another option. The simplest solution is to drop boost by 0.5 like mentioned above. Mike |
11-03-2015, 12:30 PM | #20 |
27
Rep 372
Agreed, I was going to order one in the next few weeks. To be fair this is the first I have heard of anyone having issues with the Stage 1 "Buy a full JB4" isn't the right answer in mind when issues arise.
2007 E92 335i - SOLD
2008 E92 335i - SOLD 2008 G37S - SOLD 2005 G35S - SOLD 1988 RX7 TURBO II - SOLD but never forgotten |
11-03-2015, 12:35 PM | #21 | |
4920
Rep 115,999
Mike |
11-03-2015, 01:35 PM | #22 | |||
210
Rep 919
see above and below Quote:
Also the question I really want to know, does the computer throw a code when it misfires? Because I don't have any engine warning codes when it happens. Again thanks for everyone's input. I am by no means trying to bash the manufacturer, just trying to gather data and people's experience to make an informed decision... Also I am lazy so trying to trouble shoot at efficiently as possible.... lol
