11-01-2015, 01:24 PM | #1 |
The Engineer
58
Rep 197
Drives: 2020 BMW M5 Competition
About to add ER Catless Downpipes...
What change in sound should I expect?
I currently have the Dinan "axle-back" setup, and I am very happy with the sound. I'm installing the Downpipes for performance, but even further improved sound would be a bonus. Thanks in advance for any insight.
2015 DCT Alpine White M4
BMS JB4, BMS Intake, ER Chargepipes ER Downpipes, Dinan Axle Back Exhaust Carbon Fiber Rear Spoiler, Diffuser, Splitters |
11-01-2015, 02:19 PM | #3 |
Coder
574
Rep 1,548
Are you running a tune? You will definitely get a big difference in sound. As far as gains, running a tuner will show significant gains. If not, you should get a CEL, unless you got CEL Delete.
11-01-2015, 04:06 PM | #4 | |
The Engineer
58
Rep 197
I got it new online and installed myself in my garage by backing my car up onto GoRhino oil change ramps, climbing underneath and going to work. It sounds a little louder, deeper tone, with more rumble and gurgles. Same valve function. It was the least expensive of the exhaust systems I was looking at. Probably came down to Dinan and BMW MPerf exhaust for me, and I feel like you get the same for either, and the Dinan costs less.
11-01-2015, 04:06 PM | #5 | |
Wheel Whore
539
Rep 796
Drives: 2016 F80 M3
I would say that's pretty good gains.
2016 F80 M3: BBS FI-R | JRZ RS-One | ActiveAutowerke Full System including downpipes + Swain Coating | ActiveAutowerke Active8 | Maximum PSI Intake
^Build thread link | Instagram | Facebook |
11-01-2015, 04:14 PM | #6 |
92
Rep 586
Lol no your not gaining 30whp from downpipes sorry .. i already discussed that in another treat .. your gaining 10-15whp maximum and shitty torq curve when on pump gas and theirs no gains if you use e85 on map 2 or map 7 .. thats why people being so surprised after installing downpipes and feel no gain in power .. I also had this discussion with Terry and he suggested me that downpipes aren't necessary on stock turbos and that i should not expect any gains from them .. and Stock dp flows just fine .. I was on the fence of getting them but Changed my mind going threw all this headache and Removal if going to do warranty work .. Just get nice Axle back and be done with it ..
11-01-2015, 04:15 PM | #7 | |
The Engineer
58
Rep 197
I have BMS JB4 with all connections, BMS CAI, Dinan Exhaust and some other stuff. Usually drive on JB4 Map 2 with 93 octane pump gas. My car is loud enough to turn heads and gain plenty of attention with the current mods. So my biggest concern with installing the DP's is that my car will become too loud for suburban society. I guess I could always set the exhaust valves to closed full-time, drive in "efficient" and JB4 Map 4 when in the neighborhood if needed.
11-01-2015, 04:15 PM | #8 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
11-01-2015, 04:23 PM | #9 | |
Wheel Whore
539
Rep 796
Drives: 2016 F80 M3
http://f80.bimmerpost.com/forums/sho....php?t=1179886
11-01-2015, 04:25 PM | #10 | |
92
Rep 586
11-01-2015, 06:43 PM | #11 |
Wheel Whore
539
Rep 796
Drives: 2016 F80 M3
Andrew@ActiveAutowerke
mike@x-ph.com tom @ eas Mike@N54Tuning.com Can you guys chime in on whether or not catless downpipes make power or not? From the research I've done and seen, it looks like they produce a quicker spool, better throttle response and ~25whp/wtq gains.
11-02-2015, 09:05 AM | #12 | |
The Engineer
58
Rep 197
I would also expect power gained to have a direct relationship with how much power the engine is making after other mods. So it wouldn't be surprising to me if the +30 whp is on a car with a tune and larger turbos. I would be happy with another 15-20 whp and deeper/more throaty exhaust tone.
11-02-2015, 09:12 AM | #13 | |
3441
Rep 79,211
11-02-2015, 10:04 AM | #14 |
4920
Rep 115,999
Definitely make power in the ~20/hp/tq range. Also increase Turbos spool and throttle response. On a Turbo car getting better flowing downpipes is one of the best bolt on mods you can do.
Mike |
11-02-2015, 10:17 AM | #15 | |
BimmerPost Supporting Vendor
24273
Rep 190,975
As mentioned above catless downpipes increase turbo spool and throttle response. You will feel a noticeable increase in power, but wont get 100% the gains unless you have a map optimized for your mods
11-02-2015, 11:00 AM | #16 | ||
8249
Rep 18,837
Drives: BMW
ER Downpipes see an approximate ~10whp gain on a stock platform, this is what we see in-house on our dynojet.
11-02-2015, 08:48 PM | #18 | |
92
Rep 586
11-07-2015, 04:45 PM | #19 |
The Engineer
58
Rep 197
Just installed these today.
Only had the drive home from the shop so far to try them out, but when I started her up and gave her a rev in the service drive, I instantly noticed the difference in sound. Reminded me of my GT500. For anyone considering, it's not stupid loud, but just about as far as you can go without getting there.
11-11-2015, 03:08 PM | #20 | |
In Hoc
315
Rep 626
Drives: 2016 M4 6MT MG/SO
Is there any drone when cruising on highway? Or is it just a deeper tone?
2016 M4 MG/SO 6MT- Max PSI Intakes - BMS Stage 1 - Swift Spec R - CG Precision Valve controller - 20" DPE Flowtech 5S - AA Midpipe & all the external CF goodies.
11-11-2015, 05:44 PM | #21 | |
24273
Rep 190,975
11-12-2015, 11:41 AM | #22 |
4920
Rep 115,999
