10-26-2015, 06:10 AM | #1 |
302
Rep 516
Opticoat questions
Hey guys, does anyone know how you can tell if opticoat was put on the car and or how to tell if the coating is still on the car?
I had the whole front and various high impact areas covered with ppf and paid for opticoat over the areas with ppf but i cant a difference between areas with it and w/o. No difference in beading, shine or ease of cleaning. If it was actually put on, im really glad i didnt pay for it to be put on the whole car. |
10-26-2015, 07:18 AM | #2 |
153
Rep 412
Are you sure they didn't coat the whole car in opticoat? I understand wanting ppf only over certain vulnerable areas but if you're going to apply a coating on top you'd generally apply that to the entire car and not just the film.
10-26-2015, 08:05 AM | #3 | |
129
Rep 192
shout out to Ryan http://www.autopaintguard.com great outfit |
10-26-2015, 08:08 AM | #4 |
1108
Rep 1,497
You should have the whole body coated, not just over the clear bra. Did your installer do any paint prep before he put the film on? You're going to see inconsistencies in the paint if you don't coat the whole thing. Unless you specifically told the detailer to just coat the impact areas, I'd assume he knew enough to do the whole thing. But...I would call to make sure.
10-26-2015, 10:21 AM | #5 | |
160
Rep 625
email phil@detailersdomain.com he will explain the differences and what the benefits are also. |
10-26-2015, 10:36 AM | #6 |
1113
Rep 1,904
I believe OptiCoat is a sealant (just like the Zaino family of products).
If you really want it done right (up to YOUR standards) then do it with Zaino. Its a lot cheaper but it will easily take you a full day. In the end, you get it done to what ever level you want... - Clay bar the car - One or two Z-5 applications (w/zfx to speed curing) - A single Z-2 Application (w/zfx to speed curing) - A final spritz and wipe down with Z-6 gloss enhancer You only need to do this once. Then you can do maybe one Z-2 application a year with Z-6 after each wash in between.
The Jiggery-Pokery is Strong with this One
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 |
10-26-2015, 10:49 AM | #7 | |
1252
Rep 1,760
On a side note I used to use zaino myself, but with this car opted for a DIY polymer coating and used cquartz UK. |
10-26-2015, 01:05 PM | #10 | |
1113
Rep 1,904
http://www.cleanyourcar.co.uk/zaino/.../prod_466.html
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 10-26-2015 at 01:05 PM.. Reason: content |
10-26-2015, 01:09 PM | #11 |
1113
Rep 1,904
More Zaino/sealant info here: http://www.detailingspot.com/?page_id=403
10-26-2015, 02:16 PM | #12 | |
1252
Rep 1,760
Zaino is a synthetic polymer, while czquartz/opticoat etc are nano/glass coating and SiO2 based. They are very different. The SiO2 based coatings have more durability and are very different from waxes and polymers. As I said, I used zaino for YEARS, but finally switched to a SiO2 coating with my F80. edit: not sure why this got moved to a sponsor forum instead of cosmetic wash/wax... |
10-26-2015, 02:23 PM | #13 |
1113
Rep 1,904
Despite the "glass", "quartz" , or other "ooga-booga" trademark compound names, I suspect these products are more alike than different. Nothing is going to form a true "glass" (or quartz) surface on your car despite what the trademark compounds seem to infer...
I respect that you prefer OptiCoat more than Zaino. Thats fair. I've also been using Zaino on all my cars since 2000, and I've never seen anything that produces a better, more durable surface. In any case I'll agree to disagree... BTW - Where are you in Wisconsin? I'm in Waukesha...
10-26-2015, 02:59 PM | #14 | |
1252
Rep 1,760
Yea i've been using zaino since around 2000/2001 when I had my Honda S2000. Zaino was huge on the s2ki forums. I used cquartz by the way, not opticoat. I've been trying to say there is a difference between the polymers and the silicon coatings. All of the glass/ceramic coatings (regardless of ooga booga names ) use SiO2 (silicon dioxide). So we're not just talking about marketing "fluff" or what have you. There is a very real difference between them due to the type of chemical makeup and that has nothing to do with marketing or a catchy name. |
10-26-2015, 05:00 PM | #15 |
1113
Rep 1,904
I'm betting that the Zaino ZCS is exactly the same compound...
http://www.zainostore.com/product/Z-CS.html
10-26-2015, 05:18 PM | #16 | |
1252
Rep 1,760
"From conception to realization, the principal and design emphasis of Zaino Z-CS Clear Seal was quite fundamental - an advanced total synthetic polymer protectant." I'm not trying to tell anyone that what they use is wrong by the way. I'm simply saying there is a difference between silicon coatings vs waxes and polymers. |
10-26-2015, 07:54 PM | #17 |
143
Rep 155
Time for an Opticoat story. I was a skeptic but ended up purchasing some Opticoat and doing the entire car including ppf. After 3 months I put on a second coat. Fast forward to a homeless person eating his meal off the roof of my car one evening (I was told that by a bystander). I could see extremely really deep scratches on the edges of the roof where he was leaning while dining, no doubt due to all the grit on his sleeves.
After aggressive machine-work the scratches were brought to cosmetic acceptability, but as I started the final machine-polish I could see the body color coming off on a diaper I was using to clean the compound off with. The clear coat was gone. Over the next few days I put on multiple coats of Opticoat, curing it with a hair dryer after air drying, aiming in addition to filling what was left of the scratches with Opticoat. By now I was comfortable with my understanding of how Opticoat set up and cured. Another 3 months of recommended curing time later I experimented with what it took to get down to the color coat by working through the Opticat via machine-polishing. The somewhat surprising answer is that Opticoat held up extremely well (I never did see body color come off), so that tells me it really does what the manufacturer claims. My guess is good prep is critical to good results, and in my judgement it clearly is a separate category of product from polishes and sealants. |
10-27-2015, 01:33 AM | #18 |
143
Rep 155
Sorry OP, but to answer your question, I don't really think there is a way to tell. Side by side, yes, but having done it on two cars already I'd be hard-pressed to say there is a definitive test and I can't recall that anything at all struck me as "changed" following the application on ppf.
