10-16-2015, 05:19 PM | #1 |
1326
Rep 1,481
Test Fit: Aggressive Offset BBS LM-R
Took these off my old car, mounted fresh tires from Supremepower and test fitted it the day I drove my car home.. Looks like the fitment is 50/50 if it'll rub when dropped, I'll probably try to dial in camber to -1.6 to -1.8 if possible to avoid rubbing once I get my springs in. Chime in on amount of camber needed? This is Pretty much equivalent to OEM setup with +20 spacers in front and +22 spacers in rear. Specs are 20x9 ET8 w/ 255/30/20 20x10 ET18 w/ 275/30/20 Hankook Evo 2 Soon as suspension comes in I'll get this monster truck of a car sitting nice. Haven't test drove it for rubbing yet though. |
10-16-2015, 06:08 PM | #3 | |
1326
Rep 1,481
I'm hoping -2 maximum will do.. -2.5 is too aggressive for me. I'll see what west end can do with swift springs.. What were your camber specs after alignment if you don't mind sharing? |
10-16-2015, 06:12 PM | #4 | |
6580
Rep 5,304
On the stock camber adjustment, I'm not sure how much you can actually go... I think you can go a little more than -2.0 for the rears. The fronts... not so much. |
10-16-2015, 06:47 PM | #6 |
1326
Rep 1,481
I will tonight as soon as soon I get a chance. Car is less than 24 hours new and i'm at work like a little boy before christmas waiting to play with his toy. The car's chassis/suspension is so stiff I literally could not compress the suspension with gym weights under neath one tire nor lifted up on opposing corner..
If I can get around -2.0 like you, I think i'll be ok. I just figured most people weren't able to dial in that much negative camber on a mild drop (swifts). |
10-27-2015, 02:03 PM | #7 |
219
Rep 949
I just test fitted mine also. I'm starting the the build out to make them wider and they should fit perfectly. I should be able to run a 265/295 and not rub at all. Here is a shot from the test fit
10-27-2015, 03:08 PM | #8 |
710
Rep 1,405
you should be fine, it looks like the suspension has not settle yet.. but there is people running 11 with a 35 offset so your set up should not be a problem..
10-27-2015, 03:14 PM | #9 | |
1326
Rep 1,481
Just an update, I don't rub anywhere unless on full lock. But I don't rub on the metal fender, I actually rub at the INNER area behind the wheel; for example if wheel is full lock to left (driver side), then the rubbing occurs on the side of the wheel closest to the driver on the polished lip side of the wheel and rubs on the fender liner - its really slight, I can avoid it by not going full lock. Last edited by JamesGames; 10-27-2015 at 03:20 PM.. |
10-27-2015, 03:22 PM | #10 | |
219
Rep 949
The wheel specs are 100% identical to yours. I didnt run this setup at all. i just test fitted it, and now the wheels are apart to be rebuilt. |
10-27-2015, 03:45 PM | #11 | |
1326
Rep 1,481
10-28-2015, 02:58 AM | #13 | |
9159
Rep 14,521
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
10-28-2015, 07:09 AM | #14 | ||
219
Rep 949
10-28-2015, 07:13 AM | #15 | |
219
Rep 949
10-28-2015, 12:58 PM | #16 |
1326
Rep 1,481
Agree. Front and rear is extremely tight, the front with a 255/30 is slightly less protruding than the rear with 275/30. Right now I don't rub, but will update when I am dropped.
10-28-2015, 01:10 PM | #17 |
Supreme Leader
2284
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
The wheels are going to look great after the drop James
Need to get rid of that 4x4 gap! lol classic6 Man, love your build and wheel tastes. Can't wait to see the pics once everything's dialed in
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. |
10-28-2015, 07:26 PM | #18 |
668
Rep 7,148
That white sedan is proof that a drop changes the whole car.
Without a drop in your first pics the wheels and car just look meh at best (sorry, just being honest). Add in the element of low and the wheels actually look phenomenal on the car! Post up pics once your springs are on, I have a feeling these will look great!
2016 F80 M3 Mineral White/Sakhir Orange
2013 BMW S1000RR Flat Silver <stolen> 2007 BMW E92 335i Jet Black/Jade Grey <sold> |
10-28-2015, 07:38 PM | #19 | |
1326
Rep 1,481
10-29-2015, 03:37 PM | #20 |
2312
Rep 12,654
This is probably the best stance I have seen on any F8x. Nice work!
10-29-2015, 05:41 PM | #22 |
707
Rep 886
I just dont get why people want to run 295's in the rear when we have room for 315's, or even 305's if you want to be more conservative. Wouldn't you want MORE traction?
a 19x11 +44 rear will fit a 305 and 315 no problem, especially if its not an R-comp tire
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
