09-19-2015, 07:30 AM | #1 |
53
Rep 196
Will me E92 rear setup work on f80
All I've read through setups and I know the details for stock but I really need some input on whether my e92 rear setup will work on an f80. I have 10.5 work Brombacher with an et of 19 but I'd be running a tire size of 275/35 I see people running 11 and 11.5 with 40mm offset but running 305. I'm thinking my setup would be tight but as long as I run a 275/35 it should work. I know not meaty enough!!! I think for sure with some minor camber adjustment it would definitely work. Any input would be appreciated.
09-19-2015, 09:19 AM | #2 |
721
Rep 2,342
Yes. Works for me anyway.
I put my 19 x 10.5 et 22 Work CR Kiwami's from my E92 on my F80. Rubbed with the 295/30's I was using but Put the stock 275/35 michelins on and it clears with no issues. I am lowered on H&R Super sport. I may be able to run a 285 if the manufacturer has a 285 that runs slightly narrow section width. |
09-19-2015, 10:43 AM | #4 |
1326
Rep 1,481
Post pictures or update when you mount please, I have bbs lm-r 20x10 +18 that I want to fit but I really don't want to run a 275 as well if I can squeeze a 285.. I'm guessing the only 285 that would fit would be toyo t1r and Hankook evo2.
