09-17-2015, 12:09 AM | #1 |
Rep 34
WTB: Winter Setup F80 M3
Looking for a set of winters for my F80 M3. Prefer a square 19x 8.5 ET15 square setup but open to any offers. 255/35-19 size tires (Prefer Hakka R2 or Blizzaks, snows very heavy in Alberta, Canada. Please message me what you have. Thank you! |
09-17-2015, 01:11 PM | #2 |
Rep 5
Does anyone know if previous generation Style 67 wheels from the e46 M3 will fit on an f80/f82 as a winter tire package? Style 67 are OEM quality and readily available at reasonable prices. If someone has tried this maybe the OP and other can benefit from your experience.
They came in 18 and 19 sizes. Sizes ans pictures posted below. 18 size Front Wheels: 18" x 8" -- Bolt Pattern = 5x120mm. Offset = ET47 Rear Wheels: 18" x 9" -- Bolt Pattern = 5x120mm. Offset = ET26 (Maybe square the rears) 19 size Front Wheels: 19" x 8" -- Bolt Pattern = 5x120mm. Offset = ET47 Rear Wheels: 19" x 9.5" -- Bolt Pattern = 5x120mm. Offset = ET27 |
09-18-2015, 09:39 AM | #4 |
Rep 5
If someone is in the DC area has an F80 and wants to find out for the board I have two sets of e46 m3 18 wheels.
I dont see why it won't fit over non-CCB cars, and open to finding out. I think to say so without any actual reason is just speculation. e46 m3 19s should easily clear, where the 18s f80 wheels do. Also if you look at the specs of the e46 m3 rear wheel and the f80 m3 front wheel, they're almost identical. Could do a square setup of e46 m3 rears and use a spacer in the back. e46 M3 Front Wheels: 18" x 8" -- Bolt Pattern = 5x120mm. Offset = ET47 Rear Wheels: 18" x 9" -- Bolt Pattern = 5x120mm. Offset = ET26 F80 Style 513M Front Wheels: 18x9.0 (ET29) Rear Wheels: 18x10.0 (ET40) |
