08-23-2015, 09:46 AM | #1 |
28
Rep 152
5 oxygen sensor OBD codes. Help!
I've got an N54 with 50,000 miles on it. Just replaced spark plugs with OEM BMW ones.
I just had my bank 1 after-cat oxygen sensor changed, and now I'm getting these codes: 23C2 lambda probe in front of catalytic converter 2, trimming control. 2C6A lambda probe behind catalytic converter, muddled. 2C7E lambda probe behind catalytic converter, trimming control. 2C6C lambda probe behind catalytic converter 2, system check. 2C31 lambda probe in front of catalytic converter, trimming control. What could be causing this? Last edited by febul; 08-25-2015 at 10:21 AM.. |
08-25-2015, 11:45 AM | #3 |
375
Rep 2,388
Drives: M2 Competition
Maybe you have bank 1 and bank 2 oxygen sensors switched?
08-25-2015, 03:29 PM | #4 |
28
Rep 152
08-27-2015, 07:17 AM | #6 |
28
Rep 152
08-28-2015, 07:22 AM | #7 |
Civil Rights Activist
115
Rep 949
May I ask what you used to read these codes?
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame. BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets |
09-01-2015, 10:08 AM | #11 |
Joint Chiefs of Staff
24279
Rep 190,975
Start by clearing the codes and checking if it comes back.
How is the car running? If idle is rough, check if the sensors were switched by mistake.
09-19-2015, 04:07 PM | #12 |
28
Rep 152
02-23-2016, 04:34 PM | #14 |
28
Rep 381
The dealer said engine light comes on at 4k rpm and what is causing it is the 4 o2 sensors. Is there a way to bypass or simulate the o2 sensors?
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000 2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive |
03-06-2016, 11:00 AM | #15 |
28
Rep 152
03-07-2016, 05:02 PM | #16 |
28
Rep 381
I'll check it out, Is that a Burger Tuning Down pipe? thanks
05-28-2018, 11:14 AM | #18 |
Rep 13
Drives: E82 VTT 2+ E30 FBO
I had the same issue because of an exhaust leak after DP installation. It ended up burning my rear o2 sensors and was giving me the trimming codes. The other possibility is that you got a bad o2 sensor if you bought a new one and/or the o2 sensor bulb was damaged during the install.
05-28-2018, 06:48 PM | #19 |
1542
Rep 3,071
Start by flashing back to stock. Does it happen on stock tune?
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
09-23-2018, 03:28 PM | #20 |
11
Rep 89
I'm having the same problem as well. 2C7E code has been haunting me for a while. The car drives fine after I reset the adaptations, but after a few cycles it starts throwing the same code again. I just replaced both o2 sensors in the downpipes and car ran great for a while, then when I was driving this morning the code popped back up. I have no clue what else to do?!?!
~19T turbos upgrade by turbo labs~3.5 Bar Tmap~PR Ignition Kit~VRSF Inlets and outlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~ Turner solid engine and transmission mounts~
09-24-2018, 11:06 AM | #21 | |
More Boost?
59
Rep 283
Update JB4 and reset the adaptations? |
AWCR1MC11.00 |
