M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      08-20-2015, 10:51 AM   #1
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
812
Drives: 2013 BMW M5 | MSR Stage 3
BMS Stage 1 > JB4 Upgrade
I finally got around to installing my JB4 upgrade kit and wanted to share my install experience and hope it helps the others out. Took me 2 hours to do. I was slow and first time pulling his stuff apart.
Order upgrade kit from here: (You do need the Stage 1 in order to upgrade)
http://www.burgertuning.com/N63_JB4_upgrades.html
BMS Instructions for install
http://www.n54tech.com/forums/showthread.php?t=31292
When you order your BMS JB4 Upgrade kit from BMS, you will receive the following:
JB4 Circuit Board (No Case)
OBD II Cable
1 x Brown & 1 x Green Wires
Two Twist-On Wire Connectors
What I used to complete my install:
- Body Clip Removal Tool (Remove plastic panels on the L/R of engine)
- 3/8 Heat Shrink for the OBD terminations
- 1/4 Heat Shrink to heat shrink the Brown/Green cables together
- 12" screw driver
- Zip Ties or Velco
- Heat Gun or Torch for heatshrink
- Pull string (if you'd like)
- bullet splice (I am not a fan of twist on wire connectors)
- Torx screw set.
- Download firmware from http://www.n54tech.com/forums/showthread.php?t=31292
Exterior
1) Disconnect your battery
2) Remove L/R covers (see picture)
3) Disconnect your Stage 1 Box & Swap the internal circuit board with JB4
4) Take apart the black AMP connector (beware, nuts are small and will fall)
5) Squeeze the rubber ring holding the wires on the sides and one by one pull the brown and green wires through OBDII end first. Do not try to push the PINs through as they will bend.
6) Once pulled through, push Green CAN PIN into PIN 2 on the AMP connector and Brown CAN PIN into PIN 15.
7) Take the Green/Brown wires and pull them through the 1/4 heat shrink and shrink it using the heat gun. I used a wire hanger to run through the heat shrink and then use to pull the wires through with the OBD end first.
8) Terminate the bullet splices on the end of green/brown wires where it will connect to OBDII
9) Run the two wires underneath the plastic shielding below the center window. I used pull string first and pull it through but you can pull the edge of the cover back where it touches the bay and push it through. If you want, you can just remove it as well but I didn't want to hassle with it.
Interior - I did not get pictures
1) Underneath the dash, there are 4 screws (Torx). The two small screws futher away need to be undone first. The remove the two larger cloest to you which is for the airbag. Everything snaps off and the airbag once unsnapped at the bottom will be pulled away to unlatch from the bottom panel. I didn't disconnect, left it all hanging.
2) Take your 12" screw driver, and next to the large bundle of wires coming in, about 6" to the right, I pushed it through the fabric and then attached a pull string to it and fed it to the engine bay and pulled it through and out. I did this because its way to tight to try to feed the cable from underneath the car into the bay.
3) Attach the OBD cable to the pull string inside the cabin. I tied the pull string around the cable and then taped it. pulled the string from the engine bay all the way until leaving on enough on the interior side to connect to the OBD II.
4) Take the OBD II connector and push it trough the large square entry where the foam attaches (you'll see what I am talking about when you drop the tray) and connect the OBD connector.
5) Mount the airbag to the tray, it has to be slid on from the top onto the top of the tray and then push everything back in place and screw back in.
6) Terminate bullet splices to the end of the OBD cables.
7) Slide 3/8 heat shrink over the cable
8) Terminate the Green/Brown cables to the OBD (Green on Green / Brown on Brown)
9) Test that you have a complete connection to the JB4 and Wheel controls work (see wheel control instruction video to test)
10) Slide heat shrink over terminations and shrink it down using heat gun.
11) Dress everything in using zip ties.
12) Install Right plastic cover.
13) Reinstall your AMP connector cover for the cable (If you have the aluminum cover, no need to install cover.
14) Dress in all the cables
15) Mount your JB4 box how you would like it (I upgraded to aluminum and was able to install mine between engine bay and the square box against the body panel. I believe its the cabin filter but could be wrong. See my pictures.
16) Upgrade firmware on the JB4. Download from http://www.n54tech.com/forums/showthread.php?t=31292
17) Install Left Cover.
NOTE:
If you ordered your aluminum cover to replace the plastic, you do not need to install the AMP connector covers. Use the screws that came with your JB4 kit.
s63tu JB4 MAP GUIDE:
Map 0: JB4 disabled
Map 1: 19psi peak
Map 2: 22psi peak
Map 3: 18psi peak
Map 4: Stock map w/ CANbus enabled
Map 5: Not used
Map 6: Custom target map
Map 7: 25psi peak (e.g. race gas)
Map 8: Progressive meth map. Peak boost based on meth additive. 0 = 19psi, 75 = 28psi
Note without BCM all maps, especially the higher target maps, will under target on boost.
Current dash settings as of OBDII v1.2 firmware:
'OBDII In Dash Menu
Instructions for use:
'0 map menu, map shown on tach
'1 Active Sound MUTE
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use.
'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation.
'4 OBDII Diagnostic Code Delete
'5 1st gear boost limiter
'6 2nd gear boost limiter
'7 3rd gear boost limiter
Pictures are not in any order.
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
      08-23-2015, 04:17 PM   #2
lfelunden
lfelunden's Avatar
Germany
60
Drives: BMW M5 F10
Nice write-up!!
I just ordered the JB4 upgrade for my stage 1
So, the maps only work correctly if you got the BCM?
      08-24-2015, 07:22 AM   #3
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
Damn, this is WAY more involved than the Stage 1. They still don't have the BCM's available yet but will soon. I'll come back here for sure when it's time to install. Thanks in advance.
      08-24-2015, 09:26 AM   #4
13M5F10
13M5F10's Avatar
812
To be honest, its not as hard as it looks, I went a step further to do a cleaner install (ie with the heat shrink, splicers, and such).
The hardest part for me was being in the tight space to route the OBD connector through the firewall. I am 6'4 and 280lbs so it wasn't pleasant. Once routed, its super easy.
I hear the BCM will be the tough one.
      08-24-2015, 09:33 AM   #5
13M5F10
13M5F10's Avatar
812
Originally Posted by lfelunden View Post
Nice write-up!!
It's my understanding that it doesn't produce much more power than Stage 1 at the moment until BCM is out. The maps work but don't hit the target boost.
      08-24-2015, 10:24 AM   #6
lfelunden
lfelunden's Avatar
Germany
60
Drives: BMW M5 F10
Nice write-up!!
Yep, can't wait for the BCM.. That is a game changer for people with stock exhaust/dp
      08-24-2015, 11:13 AM   #7
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
Nah, this is a game changer for those who don't want to do a Flash Tune by opening up the ECU physically. I too am waiting for the BCM. Even with the Stage 1, with exhaust and catless downpipes, people make good power, but with the new JB4 + BCM and stock exhaust with stock downpipes, people will be making more power than the setup I just mentioned. With JB4, BCM, catless downpipes, exhaust and maybe an MSR intake, crazy power levels will be achieved, even better to do meth and run high octane too, all without Flash Tuning. It will be very interesting to see a JB4 + BCM M5 go up against a flash tuned M5 in the future.
      08-24-2015, 01:45 PM   #8
lfelunden
lfelunden's Avatar
Germany
60
Drives: BMW M5 F10
Soon, the ECUs can be unlocked via bootmode, then one can read/write via OBD That's what I'm going to do and I'll use the JB4 to fine tune the car. No doubt, I would want the BCM module now
      08-25-2015, 12:59 AM   #9
MCarsFan
MCarsFan's Avatar
363
Drives: 2014 BMW M5 F10 CP
2014 BMW F10 M5  [10.00]
13F10M5 and I will run when it arrives
2014 BMW F10 M5 ZCP | SSII / Black | MSR Stage III | MSR Intakes | RPi GTM Exhaust | RPi Catless Downpipes |RW Carbon Front Lip | RW Carbon Diffuser | RW Carbon Trunk Spoiler |
      08-25-2015, 07:40 PM   #10
allmotor_2000
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1087
Drives: 2018 RS3, 991 Turbo
OR, you can do ECU Flash + JB4 + BCM + DP + Exhaust + MSR + Meth + turbo...
      08-25-2015, 09:23 PM   #11
13M5F10
13M5F10's Avatar
812
I plan to do DP/Tune in the next few weeks I hope if all goes well
      08-26-2015, 08:02 AM   #12
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
Heh heh, of course brotha. Only good for rolling races though.
I have a feeling a stock next generation M5 with hybrid assist AWD will outperform the setup you just described above in the 0-60 and the 1/4 mile. Well maybe the 1/4 mile. Lol!
      09-05-2015, 08:40 AM   #13
LuvMyM5_GP
Drives: BMW M5 F10
Very interesting read, Thanks guys
      09-09-2015, 07:55 PM   #14
Msizzle
165
Drives: 2013 M6 Coupe
what is a bcm?
      09-09-2015, 10:45 PM   #15
13M5F10
13M5F10's Avatar
812
Originally Posted by Msizzle
what is a bcm?
Boost Control Module
      09-20-2015, 04:54 AM   #16
StevanM5
StevanM5's Avatar
19
Drives: M5 F10
Also waiting for release...
m5post
