07-28-2015, 10:19 PM | #1 |
1785
Rep 3,066
pressure washer for home detailing
best pressure washer for home detailing? Looking to spend $100-200 for weekend detailing on my F30/F80. What is a safe pressure and best GPM? Looking to use in conjunction with a foam cannon.
07-29-2015, 07:13 AM | #2 | |
Gone Fishin’
7318
Rep 12,125
http://www.amazon.com/gp/product/B00...ilpage_o02_s00 I also ended up adding a longer hose. |
07-29-2015, 10:58 AM | #3 |
1860
Rep 2,104
I think most of the pressure washers in that range are similar. They're decent, but will likely break in a few years. Still money well spent. The Sun Joe mentioned would be just fine IMO. As far as a safe pressure, I'd think anything under 2000psi, but just don't hold it too close to the car; you're not really trying to pressure scrub all the dirt off, just providing that initial layer of lube to get some of the dirt/dust away.
They're all about the same GPM. For me, lower is better, to conserve water. A foam cannon is a must IMO. That's the main reason I have a pressure washer |
07-29-2015, 12:29 PM | #5 |
1860
Rep 2,104
Each pressure washer's fittings are slightly different. I'm not familiar with the Sun Joe. I went to Home Depot with part of my wand/gun, and made sure the quick connects were the right one. There are many options for male/female and sizes; it can be a bit tough to shop online, unless you know exactly what you need.
I have the MTM foam cannon; bought it from Amazon. Seems like the same one all the auto detail places sell, but without their logo. Works very well. Came with a quick disconnect, and I just bought one to match it. |
07-29-2015, 01:00 PM | #6 | |
Gone Fishin’
7318
Rep 12,125
Foam Lance - The male connector will snap right into the end of the Sun Joe. http://www.amazon.com/Professional-F...mtm+foam+lance Quick Connect Kit - http://www.amazon.com/Powerwasher-80..._bxgy_86_img_z Longer Hose - http://www.amazon.com/gp/product/B00...rch_detailpage |
08-06-2015, 01:27 PM | #7 |
Rep 19
I've got the Ryobi that I picked up from Home Depot. It's fine, price was right ($150ish) and more than powerful enough for the job. Body shop guy I spoke to said going over 1700 could get you in trouble if you're not careful.
I also have that foam lance and the quick connect it comes with works with my washer. |
08-13-2015, 09:01 AM | #8 |
Gone Fishin’
7318
Rep 12,125
The sun joe is on sale for $149 again on Amazon... http://www.amazon.com/gp/product/B00...ilpage_o00_s00
08-13-2015, 09:41 AM | #9 |
30
Rep 43
I also bought the Ryobi from Home Depot. Used in conjunction with the MTM Foam Cannon they work great!
I will say however that the quick disconnect fitting that came with the MTM wouldn't fit into the tip of the Ryobi. I had to go to home depot and get one of the brass fittings they have sitting next to the pressure washers. It was like $3 or $4. You probably don't NEED to use teflon/plumbers tape with it, but I usually throw a 1 or 2 inch piece on the threads of every quick disconnect fitting I use. MTM Foam Cannon: http://www.amazon.com/gp/product/B00...ilpage_o00_s02 Ryobi Pressure Washer: http://www.homedepot.com/p/Ryobi-170...4122/203800590 |
08-13-2015, 12:32 PM | #10 |
267
Rep 885
I bought one that had a HONDA engine.
it flows like 2.3GPM the quick disconnect fitting from the CG foam cannon didn't fit. used the screw on fitting for now but will make a trip to HD for the proper one. I don't go closer than 2 ft to the surface and use the 40 deg head. |
08-18-2015, 11:03 AM | #11 | |
220
Rep 433
______________________________
?05 E46 M3 ZCP 6MT ?06 C55 AMG '97 911S 6MT |
