07-16-2015, 08:45 AM | #1 |
Gone Fishin’
7318
Rep 12,125
Hydes Rust Stopper
Ever since I got my Satin Black wheels I have been having a very hard time with the orange rust dust that flies off the rotors the first time you brake post wash. I was looking at products online and found this Hydes Rust Stopper.
https://www.detailersdomain.com/prod...erum-rustopper Has anyone tried this? DetailersDomain is this safe on the M3 brakes? |
07-16-2015, 11:15 AM | #2 |
344
Rep 573
I would like to know too! I usually find a nice orange puddle on my wheels after washing. Then after my first drive, orange dust on my wheels. I've gone as far as removing my wheels to clean them then put them back on my car. Gets a better clean, especially around the brakes, but it's a PITA!
07-16-2015, 12:40 PM | #4 |
1792
Rep 4,216
I usually give the wheels a wipe with a damp microfiber cloth after the first drive post-wash (yup, I have a dedicated cloth just for that purpose). After a few days, the rears stay clean but the fronts end up collecting a fair amount of brake dust. No winning this game, unless you go CCBs.
2020 F87 M2 Competition /l\ LBB /i\ Executive Package 2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV BMW CCA Member |
07-16-2015, 01:15 PM | #5 | |
142
Rep 555
07-16-2015, 01:18 PM | #6 | ||
1792
Rep 4,216
07-16-2015, 01:53 PM | #7 | |
142
Rep 555
Wiping the rust off doesn't work for me. It's not 100%. There is still a little forming on the rotors, and it's a PITA. |
07-16-2015, 10:51 PM | #8 |
122
Rep 185
I use Hyde's Serum every time I wash my car. While it makes a noticeable difference in terms of decreasing the amount of rust, it is not a panacea. I think the biggest difference is aesthetics in that the rotor surface itself does not automatically turn rusty. So in that regard, it does work. However, you will still have to deal with the orange rust issue, there just isn't as much of it. My process now is that after I am finished detailing, I take my car for a quick spin to work out any rust. Then, I use Griots Speed Shine and my dedicated wheel micro fibers to gently remove any rusty residue. I can confirm there is less but there is still some annoying rust that needs to be wiped away. I tried blowing off the rust with a leaf blower but to no avail and my black wheels are coated with Opti Coat Pro which makes the wheel surface pretty slick. Unfortunatley, you do need to do a second pass. To test my theory, I sprayed Hyde's on one front rotor and left the other without. No question that the wheel with it had considerably less rust to contend with. The other issue I have is that I detail my wheels first and have to be careful of overspray hitting the rotors that have been treated when detailing the body because the serum itself comes off rather easily. I have used Hyde's for a few months on my black wheels and have not noticed any damage on the wheels, rotors or calipers related to the serum.
07-17-2015, 09:59 AM | #9 | |
Gone Fishin’
7318
Rep 12,125
I was going to pay to have my wheels OptiCoated but not sure its worth it after reading this. Did they do your faces AND barrels?? |
07-17-2015, 10:29 PM | #10 |
131
Rep 230
Glad to see that i'm not only one that has the post wash orange soup in the grove on the inside of the wheels.
Here is my way of reducing the rust juice to a minimum post wash. Some people may say that i'm wrong but I still think it's an acceptable idea. I wash the entire car trying not to wet the wheels (especially the rotors). So I do not aim the pressure washer directly at the wheels. When all of the car is cleaned, I rince and hand wash my wheels. It takes me approximately 15 minutes for the 4 wheels. So rust has only about 15 to 4 minutes to form on the rotors. Last wheel just having been exposed to water. Then I rince the car completely with my power washer making sure that no dirt from washing the wheels that could have gone on the paint is left there. Then I take the car for a one minute slow speed ride to dry the rotors and get excess water off the wheels and from the inside of the rotors (in the ventitalation channels of the rotors). Then I dry my car making sure not to scracth to paint with the slight debris than could have come up on the rockers and lower rear bumper behind the rear wheels. By using this technique there is a lot less orange juice since the rotors have about 15 to 4 minutes to rust before they are dried, instead of about an hour to an hour and a half if I wet the wheels and rotors when I start to wash my M3. If you don't drive your car after washing it and leave it in the garage with wet rotors overnight for example, you are going to get major orange juice on your rims even rust debris (like grains of salt). I would also get rusty juice stain on my garage floor. Basically try to diminish the time your rotors are wet to a minimum. |
07-18-2015, 08:02 AM | #11 |
122
Rep 185
Yes. The detailer removed the wheels and did the face and barrels. Initially I was worried the heat generated around the wheels would quickly remove the Opti. However, it has been 4 months and water still beads like crazy on them. That being said, the rust covers the wheels and clings to them. Perhaps Opti makes rust removal easier or protects the wheels for marring and light swirls but you still have to address the rust. I try to keep the touching of my black wheels to a minimum because I swear if you breathe on them too hard the surface gets imperfections.
08-05-2015, 08:52 PM | #12 |
Rep 19
Welp, I'm glad I'm not the only one who considers crazy measures to fight the orange dust of doom.
This is what I do, though it doesn't solve the rust problem, just the most efficient way I've found so far. 1) Sonax and rinse (I'll probably stop this, doesn't seem to overall help total rust amount) 2) Wash car and pressure wash wheels, avoid rotor. Dry all but wheels. 3) Wash wheels with gentle hose spray, drying any splatter. Surprisingly little. 4) Compressed air, especially rotors, bolts, and puddle areas, then dry 5) Wait X hours 6) Take for a spin to grind rust off rotors 7) compressed air rust dust, finish with damp microfiber 8) cry and question life choices Last edited by foobarmontoya; 08-05-2015 at 08:53 PM.. Reason: Grammars |
08-06-2015, 07:43 PM | #13 |
1586
Rep 2,148
I used Hyde's after every wash before I went CCB. Like what already said, it's not perfect. It does work though.
I used to spray with Hyde's a then do this. |
08-09-2015, 07:21 PM | #14 |
344
Rep 573
Finally tried out Hyde's and it works pretty well. Here's my routine:
1) rinse wheels with spotless system and pressure washer then spray Hyde's on the rotors. 2) wash wheels, rinse, then spray Hyde's again 3) dry wheels with microfiber towels, gently wipe off rotors with a separate towel and blow dry with Airblaster sidekick (gets all the little drops hidden in cracks) 4) let sit overnight to completely dry No more rust! |
08-23-2015, 10:13 AM | #15 |
BimmerPost Supporting Vendor
1997
Rep 6,916
everything stated here is true, that being said this is a product will not rid you of rust on the rotors permanently, it will reduce the amount of rust greatly after the wash if done right.
08-27-2015, 01:23 PM | #16 | |
1860
Rep 2,104
08-27-2015, 07:46 PM | #17 |
920
Rep 1,481
Since you mentioned in another thread that you have the CR Spotless, do you find that it helps to cut down the rust on the rotors?
2015 Mineral Grey ///M4 6MT
08-27-2015, 09:45 PM | #18 | |
344
Rep 573
Just helps with the water spots on the black wheels.
"When you're racing, it's life. Anything that happens before or after is just waiting."
08-28-2015, 03:29 PM | #19 |
1860
Rep 2,104
Ya, it does nothing for the rust. But it does give you 0 TDS water, and you can basically wash your car in the sunlight and just walk away. I like mine a lot. Now if we just didn't have this damn drought in Cali, I could use it more often
08-28-2015, 03:45 PM | #20 | |
920
Rep 1,481
08-28-2015, 05:21 PM | #21 | ||
344
Rep 573
08-28-2015, 05:46 PM | #22 | |
920
Rep 1,481
It does significantly reduce the amount of rust if it is applied (like you seem to do) each time the rotors get wet. If you are just washing the wheels, it is a good solution. But if you are washing the wheels and then the rest of the car, you have to keep applying it (and wiping off the excess) multiple times. In the end, this doesn't save me any time compared to just going for a short drive after washing and drying the car to clear the rust from the rotors and then wiping the wheels with a microfiber cloth and a detailer.
