07-08-2015, 11:33 AM | #1 |
43
Rep 62
M3 GT4 ABS/DSC Fault
Please can someone help?
The ABS/DSC still periodically shows a fault. The codes are; D355 (Engine 169), D35A (CAS 304), D354 (Engine 168), D354 (Engine 168), 5E18 (Interface) and 9520. All the wheel speed sensors have been change but we still occasionally get the fault. What component is failing? Thanks |
07-11-2015, 05:20 AM | #3 |
70
Rep 287
ABS pump connection was the cause for this fault on my car. I'm getting the connections resoldered by an electrical engineer to fix it based on my shops advice. Apparently it's relatively common.
Drives: 2010 E70 X5M Carbonschwarz Loved and lost: 07 E92 M3 Silverstone II / 96 E36 M3 Evo Estoril Blue / 07 E84 Z4 M Coupe Interlagos Blue |
07-11-2015, 10:08 AM | #4 |
43
Rep 62
07-21-2015, 05:22 AM | #5 |
43
Rep 62
I still have the problem..
The fault codes are; D355 (Engine 169), D355 54101 PT-CAN: Message TORQUE_2 (ID 0x0A9) not received or wrong message length (DLC). [transmitter: DME] D35A (CAS 304), Gateway Terminal 1 status message PT-CAN / CAN message Combination / CAN error message / PT CAN fault D354 (Engine 167), D354 54100 PT-CAN: Message TORQUE_1 (ID 0xA8) not received or wrong message length (DLC). [transmitter: DME] D354 (Engine 168), D354 54100 PT-CAN: Message TORQUE_1 (ID 0xA8) not received or wrong message length (DLC). [transmitter: DME] 5E18 (Interface) CAN DME/DDE Message invalid 9520 Steering malfunction: MFL mechanical faulty What component(s) are failing? |
