ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      02-17-2008, 02:02 PM   #1
vachss
55
Drives: Z4 Coupe
Yet another CDV delete thread
Finally got around to it. Didn't bother with Zeckhausen - bought a stock CDV from Tischer for $12 and modified it myself in 3 minutes with a bench vise and a length of 5/32" drill rod. The actual swap took about the 30 minutes everyone claims - the majority of it figuring how to safely jack up and get under my Z4 for the first time. Being paranoid about the whole being crushed to death thing I used 4 jackstands all on the driver's side (2 taking the actual load at the nominal jackpad support points, one under the front A-arm and one adjacent to the front jackpad as back ups.
I am not particularly given to hyperbole so I can't say the difference is night and day as others have described it. That said it does improve clutch engagement feel in 1st and 2nd to a perceptible degree and I agree with everyone else that for the minor cost/effort it's a worthwhile mod.
      02-17-2008, 04:42 PM   #2
srhutch
srhutch's Avatar
12
Drives: Z4M & F11
swapped mine out two weeks ago, noticed the difference as soon as i drive for first time, much better, wish i had done it sooner.
      02-17-2008, 05:06 PM   #3
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
You may damage the clutch hydraulics with the drilled CDV. Did you read the zeckhausen page before you proceded to do this?
http://www.zeckhausen.com/cdv.htm
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      02-17-2008, 05:14 PM   #4
Reach
gone baby gone
382
Drives: 2016 F80
As long as you're not retarded there wouldn't be a problem. Their arguments are about leaving behind shavings to work their way into the fluid system (valid point, but people will handle that) and damaging the tapered end. The second argument is about damaging the CDV's fitment. You'd only do that if you screwed with the external diameter, which I can't imagine any craftsman doing.
You do realize as a vendor of modified CDVs is their prerogative to spread a little FUD about the process. I wouldn't take their word as dogma, when plenty of others have drilled the stock one or removed theirs completely. Of course, without a clutch pedal, its not my problem.
      02-17-2008, 05:38 PM   #5
vachss
55
Drives: Z4 Coupe
To be clear I did not drill out my CDV. I used the flat end of a piece of drill rod to push out the inner guts of the valve, removed the piston, reassembled and installed. This process is discussed in detail over on Z4-forum: http://www.z4-forum.com/forum/viewto...v+drill#p17422 Given how easy it is to modify a CDV like this it amazes me that folks cough up an extra $20 to get Zeckhausen to do it for them - each to their own I guess.
      02-17-2008, 09:11 PM   #6
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Just making sure you didn't stick it under a drill press and go to town.
I'd buy zeck's just cuz i don't have the tools and I wouldn't want to screw it up
Best Website EVER!
      02-20-2008, 04:15 PM   #7
srhutch
srhutch's Avatar
12
Drives: Z4M & F11
Was going to ask you exactly what you did, but I see you used my post on Z4-forum so I wont ask anymore
      05-10-2009, 10:30 PM   #8
Z4MC4ME
Drives: 2004 Acura RSX Type-S
I apologize for thread hi-jacking, but how likely is a modified CDV going to void one's warranty? Would the service tech notice the difference in the feel of the clutch and likely report it?
I only ask as I am about to purchase a CPO Z4MC and would prefer not to jeopardize the warranty.
Thanks in advance.
      05-11-2009, 09:24 AM   #9
Kream
Drives: 07 M Coupe, 11 GLK350
Why can't you direct-link the line? Is a modified CDV reallly necessary?
      05-11-2009, 09:47 AM   #10
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
some people are worried that removing it will cause warranty issues if the dealer sees that its missing.
i myself took out the cdv completely and just re-attached the line. in my honest opinion (and i bled the clutch line afterwards) i couldnt tell a difference at all.
      05-11-2009, 10:57 AM   #11
jragan
Imola Lover
jragan's Avatar
26
Drives: 2007 Imola Red M Coupe
Removing it all together is the best way to go...If you ever have transmission/clutch issues, just make sure to replace it before you send the car to the shop.
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
zpost
