      06-26-2015, 02:35 PM   #1
Marioh
Marioh's Avatar
Drives: 2008 AW/AG 135i
Got a scuff on the car. Grabbed a microfiber, denatured alcohol and took care of the spot. Stepped back, and the panel where I worked is now green!
It looks like the microfiber dye has bled into the paint (and my hands as well). Any recommendations on removing it? Clay bar? Harsh soap and rewax the panel?
I grabbed a white terry towel + more denatured alcohol and a little bit of it came off but not all of it and I don't want to burn into the panel more than I need to.
      06-26-2015, 03:11 PM   #2
CJ///M
CJ///M's Avatar
13
Drives: 2015 BMW M4
Try clay bar.. make sure surface is extra lubricated.
      06-26-2015, 03:44 PM   #3
bmw1racer
bimmerphile, technogeek
bmw1racer's Avatar
998
Drives: 2012 E82 6MT Sport
That only takes care of surface imperfections... The denatured alcohol might've penetrated the clear coat and/or color layer.
Denatured alcohol is way too aggressive to remove a scuff, IMO... You should've started with something mild and work your way up.
      06-26-2015, 07:16 PM   #4
Gray_Panther
Gray_Panther's Avatar
1555
Drives: 128i
+1 ^
2012 BMW 128i 6MT Deep Sea Blue Metallic
      06-27-2015, 09:29 AM   #5
135TX
89
Drives: '11 135i
I've heard 50/50 water alcohol blend is good
Exhaust, Flash tune, Suspension, LSD, Wheels/tires....
Originally Posted by IEDEI View Post
You'll never regret pursuing what you really want....ever. You will, however, regret NOT doing things you wanted to do.
      06-27-2015, 09:53 AM   #6
Gray_Panther
1555
Drives: 128i
Isopropyl alcohol with water*
Denatured is intense.
      06-28-2015, 05:29 PM   #7
Detailed Image
Detailed Image's Avatar
360
Drives: Detailed by Detailed Image
If a chemical cleaner does not work, a light polish like Meguiar's M205 will surely help to remove the staining.
Zach McGovern
Detailed Image Ask-A-Pro Blog Author
www.AttentiontoDetailingPeoria.com
1addicts
