02-13-2008, 08:11 AM | #1 |
2173
Rep 5,364
M3 rear edited.
As you might have gathered, I like a lot of the new M3, but a theres quite a lot of things I dont like lol. The rear diffuser is one of them. Here a quick chop where I tidied it up:
Before: After:
02-13-2008, 08:27 AM | #2 |
Commander-In-Chief
2173
Rep 8,938
Drives: 2023 M2 Coupe, 2020 GLE 450
Not a huge fan of the rear myself, but eliminating all the openings makes the remaining shapes pretty odd and purposeless, IMO.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
02-13-2008, 08:32 AM | #3 | |
2173
Rep 5,364
One thing is for certain though, I like the way I made the bottom of the diffuser more chunky and made it wrap around the exhausts more.
02-13-2008, 08:32 AM | #4 |
218
Rep 3,592
aren't the opening there b/c of aerodynamics, it helps with the downforce as air flows through the bottom then out the back flowing through the opening and not creating lift...
'08 E92 M3 6MT | IB | FR | RAC RG63's | VRS Ti Exhaust | Fabspeed HFC & Xpipe '09 X5 35d SG/SB '11 X3 28i AW/CN/FW (wife's car |
02-13-2008, 08:34 AM | #5 |
Reincarnated
245
Rep 4,227
The lack of muffler is infinitely better.
02-13-2008, 10:10 AM | #6 |
Commander-In-Chief
2173
Rep 8,938
Diffuser
That's the theory. No data from BMW on how much it actually does. In race cars the whole bottom of the car is optomized for effectiveness, but it's a bit more difficult to do in production cars. The M3 has a comendably smooth underside, though.
02-13-2008, 01:59 PM | #7 |
26
Rep 359
If you delete the rear diffuser it will probably affect the aerodynamic balance at high speed. IMO, ACS has done a pretty good job on the rear of the M3. As mentioned in another thread, you can use the Remus tip instead of the ACS design.
02-13-2008, 02:28 PM | #8 |
Rear wheel drive fanatic
53
Rep 604
Drives: M3 E30-1M-M4
AC diffuser is nice.Like E46 csl
02-13-2008, 05:05 PM | #9 |
143
Rep 202
If anything I think it should look more functional...
[insert quick dirty photoshop here] Currently it looks a little fake and unnecessary, although I'm sure it still helps aerodynamically in some way. But why then not incorporate it on the E90? And a lot of what's changed on the above ACS ///M3 has to do with the exhaust itself, not the diffuser, as you can clearly see the rear diff exposed even more so.
-ANDY
'05 M3 CS | Silver Grey | M Cloth OEM CSL Front - Rear - CF Roof | Dinan S2 Performance Pack | 19" RAC Monolite RG4s |
02-14-2008, 04:06 AM | #10 | |
2173
Rep 5,364
02-14-2008, 05:01 AM | #12 |
///Andrew Alewine
23
Rep 709
Yeah removing that hole will affect the downforce. The diagram that was posted above are only highlighting engine covers and isn't a proper demonstration. If you were to run it through a wind tunnel the air will go over the exhaust and through that hole generating down pressure on that area in which case = Downforce.
02-14-2008, 05:30 AM | #14 |
2173
Rep 5,364
Almost. I hid the muffler, strengthened the bottom part of the diffuser and generally made it look more solid. Look:
Before: After:
02-14-2008, 06:12 AM | #15 |
1133
Rep 8,020
Why not give it something like that of the C63 or RS6, both of those has agression that tells these aren't your average run of the mill performance models when viewed from the rear. In this world where looks are everything BMW under sold the M3 short with it's end design.
