06-11-2015, 09:22 PM | #1 |
35
Rep 144
Drives: E90 M3 SSII 6MT
Valve Cover Gasket
Im starting to see a small leak on the passenger side valve cover gasket. Particularly on the 2 visible bolts beside the coolant reservoir. I've replaced numerous VCGs on many BMWs and this will be the first time with the S65 engine.
Anything i should know out of the normal? Im almost thinking to re torque the bolts for now and see how it goes but at the same time i work for BMW and i get the parts for dirt cheap. I read somewhere that this leak is pretty common with the S65 especially on the passenger side of the engine. Any input will be appreciated. Last edited by Jsantos; 06-12-2015 at 12:21 AM.. |
06-12-2015, 09:20 AM | #3 |
35
Rep 144
I couldnt find the thread you started. Did you do both valve cover gaskets?
06-12-2015, 09:29 AM | #4 |
64244
Rep 24,863
Yes it's pretty common on the S65 , and always on the same spot .
Pic is not my car , but this is how it looks .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
06-12-2015, 12:15 PM | #5 |
Bad Lieutenant
233
Rep 3,517
If those bolts have rubber grommets, try just replacing those first. They should be cheap.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
06-12-2015, 01:56 PM | #7 | |
64244
Rep 24,863
1- Look at the oil fill cap 2- 10 cm below you can see the 2 bolts on the sealing of the valve cover These are the middle and right bolt 3- Now you need to look at the bolt that you cannot see in the left corner. 2 cm below in the left corner bolt that you cannot see , you can see a darker spot under the valve cover in the most left corner (left "corner" valve bolt) =>That's the oil leak . So you can see the 2 bolts on the left side valve cover sealing , but there is also a bolt on the left side corner on the left side valve cover . It's just under that bolt in the corner . Let me know if you can see it ?
06-12-2015, 02:32 PM | #8 |
35
Rep 144
I appreciate the help guys. I decided to just get a couple of the bolts with the rubber grommets, and torque them down to spec. My oil filler cap is fine.
Does anyone know the torque specs for the bolts? Seems like this is a very common issue for the s65's, particularly on that side of the engine. That photo you sent me belgium looks exactly the same with mine. |
06-12-2015, 06:10 PM | #9 | |
Bad Lieutenant
233
Rep 3,517
Also, pick up some UV dye from amazon and leave it in there, it will be far easier to pinpoint the seep location.
