06-09-2015, 05:43 PM | #1 |
47
Rep 170
Changed wheels and tires and noticed I have no TPM in the wheels?
Is there some small device for TPM? Or does it measure at the hub?
I noticed this when I swapped the rubber out of my OEM wheels. |
06-09-2015, 10:55 PM | #2 |
72
Rep 315
Drives: 13 AWSO M5,16 DGMR X5M
Yes I don;t have it either. But i believe that the TPMS are somewhere built in the wheels. =)
2012 Rosso Mars Lamborghini Gallardo STS LP570-4
2013 AW SO F10 M5 upgrades: RKP front spoiler, M performance carbon spoiler, 3D design rear carbon diffuser, KW HAS Sleeve Kit, Akrapovic Evolution Carbon tips, ind black LCI front and rear grills, GruppeM RAM intake, 20" HRE P104 satin charcoal with PSS tires) |
06-09-2015, 11:47 PM | #4 |
39
Rep 313
It's pretty much combined in your valve stem. It's not in the hub.
Looks like the attached picture. A way to tell is if you can bend your valve stem, then you don't have it. If it is solid as pictured, then you have it. It easily can transfer over to your aftermarket wheels. |
06-10-2015, 04:20 PM | #6 |
41
Rep 112
Yes, the TPMS sensor is located in/part of the the valve stem on our F10's. If you change wheels and tires you will need another set to enable the system.
Of course you could use your old ones; though that would entail removing the tires from the Oem wheels to gain access to them. |
06-11-2015, 12:24 AM | #7 | |
23
Rep 181
if you have older car, i know on my X5 the tpms is part of the ABS system thats how it detects for flat through suspension not level |
06-11-2015, 11:15 AM | #8 |
105
Rep 806
Canadian cars don't use the valve stem TPMS. Uses the ABS sensor I believe.
2014 ///M5 CP Tanzanite Blue/Cohiba - 11.15 @ 128.8 & 1.84 60' (2150' DA) - BPM Tune - MSR Intake - SSP DCT - SS DPs & HFC Mid Pipes/X-Over - E Race Muffs - 19" MT DRs... On to a new home.
06-16-2015, 08:27 AM | #9 | |
1312
Rep 10,185
The standard in most countries is the lower cost one that uses the DSC sensors to determine if a tire is flat. Optionally you can have the full TPMS fitted (option 2VB). This one can display tire pressures and temperatures in Idrive and uses valve stem monitors. Due to regulations USA cars are fitted only with the full TPMS. You can tell if a car has the full TPMS by looking at its vale stems. If they are all metal they are usually full TPMS. Rubber ones have the lower system.
BMW if you are reading, I need a job, Please. |
06-16-2015, 05:05 PM | #11 |
1312
Rep 10,185
If you fit the correct type of TPMS sensors to your new wheels you will just have to reset the system via Idrive
06-17-2015, 09:10 PM | #12 |
9163
Rep 14,521
