XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      06-04-2015, 01:17 PM   #1
rps
rps's Avatar
35
Drives: 2013 X1
Bimmian 5 in 1 Guage
i just ordered the Bimmian OBD2 5in 1 Digital Meter. It gives: water temp, boost pressure, volts, RPM, intake and exhaust temps. It looks to be smaller than a credit card in width and length and small thickness. I'll post once it gets here. It has already shipped and it should be here in a couple of days.
NB8S Past Garage: Z4, 135i. Present Garage: 2013 X Drive X1 2.8i.
      06-05-2015, 02:25 AM   #2
Shock96
That was a hell of a thing...
22
Drives: 2013 xDrive 35i M Sport
Looking forward to the info. It is kinda like a Scanguage II right?
      06-08-2015, 03:23 PM   #3
rps
rps's Avatar
35
Drives: 2013 X1
It's here, I'll post a picture of it later if the site doesn't say it's too large.
      06-08-2015, 03:33 PM   #4
rps
rps's Avatar
35
Drives: 2013 X1
Here is a pic of it
      06-08-2015, 09:11 PM   #5
Shock96
22
Cool! That is your install right? Looks great.
How bright is the LED at night and is it adjustable? Looking forward to the review!
      06-08-2015, 11:08 PM   #6
NorCal Einstein
Drives: X1 35i MSport
Could you take a picture of the OBD connection area? The mounting you did on the headunit looks pretty clean, and I'm curious to see how cleanly you can integrate the OBD plug.
      06-09-2015, 08:47 AM   #7
rps
rps's Avatar
35
Drives: 2013 X1
Here's the pic of the OBD2 connection. The wire is hanging because it is only temporary. I will be dropping the lower panel and routing the wire behind it.
The Turbo boost is interesting to watch especially when you get on it. There is also a setting you can set for over boost. One thing that I do not know if it is normal or not is that the car is charging at 15 volts. This may be because of the stronger electrical supply, but I will check with the dealer to see if this is normal. The temperature functions seem to be ok but not something I would want to monitor all of the time.
      06-09-2015, 11:17 AM   #8
rps
rps's Avatar
35
Drives: 2013 X1
The backlighting is no bad at all at night, I can't say for sure but it has shadow mode which I believe dims the display based on ambient light.
The only down side I have found is that the temps are displayed in C without the ability to change to F.
      06-09-2015, 06:28 PM   #9
Shock96
22
Thanks RPS. Looks like a worthwhile addition.
The 15v could be concerning, but do we have a standard lead acid or is it a AGM battery?
AGM's do like a bit more voltage, but I think the additional voltage might be due to the distance it has to travel to the hatch area.
      07-07-2015, 06:55 PM   #10
rps
rps's Avatar
35
Drives: 2013 X1
My unit was hung up in battery mode, a call to Bimmian who told me to unplug it from the OBDII. I did, the unit reset, and is working correctly again.
      07-07-2015, 08:08 PM   #11
tp89
Nebraska's Finest
11
Drives: 08 SGM 135i
Would love to see a vid of the boost setting.
      08-03-2015, 03:11 PM   #12
MMacx1
MMacx1's Avatar
27
Drives: 2016 BMW 340i M
Gauge
I too would love to see a video, You Tube has nothing yet on this product.
I would love to monitor Boost, Air/Fuel, & Temp, since the X1 has none of these gauges.
      08-03-2015, 03:22 PM   #13
zeevette
Unllicensed
zeevette's Avatar
29
Drives: 2013 X1 35i
Doesn't a Burger JB4 include a boost gauge in their stg.2 tuner?
xbimmers
