06-03-2015, 12:00 AM | #1 |
12
Rep 61
N54 with 10.5 quart (10L) oil
Well, I was wrong to put that much, but I have no idea what are potential problems I will have.
Computer says oil level is OK. I put most expensive Motul 5w40. The engine sound is different now. Cruising engine temp is 250F which I think is a bit high. Second question is rough start, however no error messages. With previous oil change(7K ago) I spoiled oil by 4 cans of BG44 over 7Kmiles! I put the coils, plugs, installed 3 new injectors which were misfiring and did walnut shell cleaning (7K ago) but no oil change! Even doing that much but no oil change started to cause rough cold starts. What was it? Bad oil cause gunk growth? With new oil cold start is more or less OK. The car has 105Kmiles. Last edited by AnShk; 06-03-2015 at 12:08 AM.. |
06-03-2015, 08:43 AM | #3 |
1Addict
3237
Rep 7,897
It will come out of the engine until it gets to the proper level, which is around 7L. Possibly forcibly from any crack or gasketed area. I'd drain it out and refill properly before you damage your seals, if you haven't already.
06-03-2015, 09:38 AM | #5 | |
283
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
By putting in 10.5L of oil you are at roughly 140% of the oil capacity. This is about as big a red flag as you can get when it comes to oil changes, the only thing worse would be not re-installing the drain plug and driving with no oil. Engines are pressurized systems, having even a little bit too much oil will cause damage over time. 140% of what you need will probably cause catastrophic damage to multiple seals. Drain out your oil immediately, drive the absolute minimum you need to in order to pop the drain plug and remove the excess oil. When doing an oil change, check if the bottle is in quarts, or litres. The two are not quite the same, and the number of bottles you add will vary. Remember, it's extremely easy to add a little oil, it's not as easy to remove it. It takes about 1L from MIN to MAX on a dipstick, so if your engine takes 6.5L, add 6, then check the fluid level. This gives you a nice 0.5L buffer if all the oil didn't drain. Also remember that you need to take the car out and drive it until it's warm enough to get an accurate reading -OR- be on a level surface with the engine off. Remember, always check your owners manual for the fluid capacities BEFORE beginning your work Part 2: This sounds like your HPFP. If you haven't had the recall done already, then this is likely the problem. It could also be an install problem with the injectors, if the issue happened immediately after you finished installing them.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles Last edited by 6MT_Addict; 06-03-2015 at 10:26 AM.. |
06-03-2015, 10:23 AM | #7 | |
283
Rep 888
I've over filled previous vehicles before and used a clear bottle with capacity markings to get a good idea of how much has come out. In your case, you could just get an empty 4L milk jug, fill it, then check the oil level and go from there. What I do if I get an over fill is loosen the drain plug, but hold it in place so only a small, continuous, drain occurs. When I over filled my SUV by ~250ml, it took me 10 minutes to drain it back out with this method. Since you need to remove so much it's probably easier to just do a full oil change. This is also why it's a great idea to make sure you have the right amount of oil in prior to cleaning up. If you need to remove some, just raise the front end again and everything is right there. If it's been 7000 miles though, just drain, replace the filter, and add new oil.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
06-03-2015, 10:47 AM | #8 |
European Editor
10594
Rep 22,992
Nope, you can't. I've tried that before thru the oil filter housing. You can only get a cup or so out thru there. Best thing is to do "another" oil change. Hey you can't have too many oil changes done on a car!
06-05-2015, 04:42 PM | #9 |
12
Rep 61
Hey!
I have actually driven 400miles on 10 l oil and finally I drained the engine to 6.7l oil yesterday! I was wondering if I can use the same oil for next time? I guess it should not decompose or be so dirty, right? |
06-05-2015, 06:44 PM | #10 |
89
Rep 527
Dude I'm lucky if I see greater than 300 miles per tank
06-05-2015, 07:26 PM | #11 |
22
Rep 319
Drives: BSM e82 135i
Don't be so stingy. Just ditch the oil and buy new next time
06-05-2015, 07:53 PM | #13 |
969
Rep 3,323
He must be hypermilling.
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
06-05-2015, 08:00 PM | #14 |
California-bound
385
Rep 1,480
Jesus Christ, your poor engine.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
06-06-2015, 12:05 AM | #16 | |
12
Rep 61
well, at the moment the symptom is slightly rough cold start the same as it was in december last year when I had to change plugs, coils, 3 injectors and do engine cleaning. Now it is not cold, I guess if it will be cold I would get misfires at some point. |
06-13-2015, 07:28 AM | #17 |
36
Rep 260
you need to take your car to a mechanic or the deal for any maintenance.
08 135 SB
DCI, VRSF 7" fmic, VRSF DP, Berk street, Wavetrac!, Koni yellows, eibach sways, M3 lca, Dinan plates, poly bushings, JB4 iso5, E85, Alpina flash/m3 paddles, CP, walbro, and other crap. VVT Stg1 |
