05-18-2015, 08:41 PM | #1 |
203
Rep 699
Anyone noticed the extra brake lights?
I only found out this weekend that my E90 has an extra set of brake lights that come on only under intense braking. I was at a track event and saw it on track footage taken from another car.
Under normal braking just the normal lights on the outside come on. Under intense breaking, additional lights come on in the short bit of the L-shaped lighting cluster; cool. Now I wonder how the lights are arranged in the E93, where the shape of the cluster is different. |
05-18-2015, 09:10 PM | #4 |
529
Rep 1,122
This feature is called BFD or Brake Force Display, different from the euro hard brake flash. This is just a second stage of lights that illuminate when you brake harder than a certain threshold.
The euro brake flash is a third stage basically that flashes the lights rapidly upon abs engagement. |
05-18-2015, 09:10 PM | #5 |
6722
Rep 10,602
05-19-2015, 08:59 AM | #8 |
2386
Rep 3,740
Drives: 2018 M2
05-19-2015, 09:33 AM | #9 | |
715
Rep 746
(I kid. I kid because I love my M3) |
05-19-2015, 09:50 AM | #10 |
E92 M3
99
Rep 508
Drives: (2) E92 M3's & F30 320i
My buddy has told me that my lights flash like F1 cars in the rear when I brake heavily lol
05-19-2015, 12:26 PM | #13 |
368
Rep 1,197
Drives: 2021 F87 M2c. LBB, 6mt
I wanna see, I wanna see!!!
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
05-19-2015, 12:50 PM | #14 |
Global Moderator
6389
Rep 2,309
Drives: E90 M3 6MT
Adaptive Brake Lights or (Dynamic) Brake Force Display has been a standard safety feature on BMWs since at least the E46 generation.
Below is an E46 sedan demonstration: Most recently, you can actually see the Brake Force Display on the infamous M4 that hopped the curb. Watch closely and you'll see the primary lamps light up and then the inner [brake force display] bulbs activate shortly thereafter On the E92 Pre-LCI, the inner bulb also serves this function. These can be coded to perform an array of motions (2-step/2-stage, blinking, permanently active, active when primary brake lamps active, etc.) For most intents and purposes the bulb is sometimes identical to the "Rear Fog Lamp" & in those cases, the FRM module treats the lamp as a "Rear Fog" during coding. In tail lamps where the rear fog lamps are independent from the Brake Force Display lamps, the rear fog lamps can still be coded to act as an additional brake lamp in any combination. Below is a demonstration of the E92 Pre-LCI, but the concept is consistent for pretty much all modern BMWs. More examples: E46 coupe facelift: On the E46 coupe LEDs, the outer half ring surrounding the primary brake lamps act as the Brake Force Display. The inner tail lamp of the "L" acts as a rear fog. In this case, the rear fog and brake force displays are separate. E90 pre-LCI Inactive: Active: E85/E86 E60 LCI E61 LCI
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread |
05-19-2015, 12:52 PM | #15 |
142
Rep 1,637
05-19-2015, 12:59 PM | #16 |
4987
Rep 11,891
05-19-2015, 01:00 PM | #17 | |
4987
Rep 11,891
No I don't think feature is worth coding in. You won't be able to enjoy it, IMO |
05-19-2015, 01:08 PM | #20 | |
Global Moderator
6389
Rep 2,309
Drives: E90 M3 6MT
The fact that the M4 took flight simultaneously is just coincidence.
05-19-2015, 01:20 PM | #21 |
142
Rep 1,637
I slam on the brakes at 30mph anytime I'm next to a mirrored window. If you look hard, you can see the flashing.
05-19-2015, 02:56 PM | #22 |
2386
Rep 3,740
Drives: 2018 M2
Great! Just One more obstacle when I try to pull off insurance scams
