05-14-2015, 06:21 PM | #1 |
23
Rep 191
fs: used e9x m3 only ground control Camber/Caster Plate
hi up for sale ground control e90 / e92 / e93 m3 ( m3 model only) this was used for 6000 miles. my m3 was just a weekend car ( had this on the car for 13 months) . i had them on with the kw sleeve kit . everything works like new , nothing is broken or missing , ready for immediately used. retail price $450 or so (Product SKU #CCPE9Xm3street ) asking $310 , free shipping lower 48 states of usa I M LOCATED IN EL MONTE, CA 91733 16264872157 / CHUNG below are the info from ground control website ONLY fits E90/92 M3 with 16mm pin and stock spring diameter, for regular e9x select (Seperate item, CPe9xTouring). These plates feature over 26mm of total camber adjustment with the ability to make corrective caster changes to equalize side-to-side caster in the stock position. Other features include replaceable waterproof German axial load bearings, and urethane bushings for long life, less deflection, and a smooth silent ride on stock or stock sized aftermarket springs. Our camber plates are also engraved with the Ground Control logo and markings which can be used to locate the plate in the stock position for easy, repeatable, adjustment from street to track and back. All components are anodized or zinc plated for corrosion resistance. We also offer our lifetime guaranty! (Bearings not included) • A clean sheet design for street cars, not an adapted spherical race plate. • Waterproof, German-made, axial load steering bearings. • Allows for up to 26mm total camber adjustment. • Unique slot design allows for caster correction. • Urethane center mounts reduce NVH, yet do not flex. • All components plated or anodized for corrosion resistance. • Zinc plated mounting bracket for ease of install and adjustment. • Reuses stock rubber spring pad for noise isolation. Torque camber plate mounting nuts to 18ft/lbs using properly calibrated torque wrench. DO NOT USE PNEUMATIC TOOLS Last edited by aaaafamily; 07-22-2015 at 11:05 AM.. |
