      05-11-2015, 05:10 PM   #1
mattryan
mattryan's Avatar
86
Drives: 2022 M240i xDrive
Right cornering light malfunction then left cornering light?
Started my car yesterday and it told me "right cornering light malfunction. Not sure which right it's referring to however I checked both cornering lights and they are both functioning. Wondering if it has anything to do with the LUX AE's but I've had them for the last 3 years and no issues. I had a couple issues previously where the seal on the cover collapsed and moisture entered the headlight and caused the adaptive headlight module to short...
Current: 2022 M240i xDrive
Previous: 2018 440i xDrive, 2012 135i
      05-12-2015, 12:37 AM   #2
JL135i
27
Drives: 135i
What seal are you referring to that collapsed?
      05-12-2015, 07:01 AM   #3
mattryan
mattryan's Avatar
86
The seal around the headlight cover
      05-12-2015, 02:55 PM   #4
edisapimp
Civil Rights Activist
115
Drives: E46 Sedan, E88 Vert
OMG! NOOOoooooo
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame.
BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets
      05-12-2015, 04:07 PM   #5
JL135i
27
Drives: 135i
The headlight cover that you snap on in the back?
      05-12-2015, 04:08 PM   #6
mattryan
mattryan's Avatar
86
Yup!
      05-13-2015, 07:33 PM   #7
BigRussia
BigRussia's Avatar
152
Drives: 04 M3
I just had the dealer fix this same issue. Ive had a persistent light bulb error for about 4-5 months now. Dealer finally figured out it was the right cornering light even though it always lit up fine this whole time. I'm guessing it was a faulty bulb ground/connection or something. Well the bad news was that CPO warranty doesn't cover it, and the dealer charged $70 just for the bulb... then another $220 to 'program' it!! Program a damn light bulb?! Freaking ridiculous but I really wanted the gonging light bulb error to just go away. Good luck, maybe you wont get ripped off by your dealer like I did.
2004E46M36MTCBCinn 'Clubsport'
      05-13-2015, 07:38 PM   #8
mattryan
mattryan's Avatar
86
It's weird when I first get the error it says "Right cornering light malfunction!" then when I click on it in my iDrive it says "Left cornering light"???
      05-13-2015, 07:40 PM   #9
mattryan
mattryan's Avatar
86
$70 for ONE BULB and $220 to program it? Why does a light bulb need to be programmed???
      05-13-2015, 10:01 PM   #10
BigRussia
BigRussia's Avatar
152
Drives: 04 M3
That's what I wanted to know same thing as to why our batteries need to be programed after replacement as well.
When the SA was telling me how much it was i told him to forget, I can change a light bulb by my damn self! But he convinced me it wasn't a straight forward or easy replacement to DIY and I would still need to get the new bulb programed to get the error to go away.
I'm hoping he wasn't BSing me into blowing $220...
      05-14-2015, 04:19 AM   #11
luv135i
luv135i's Avatar
60
Drives: White
Just change it and see. I had a taillight bulb out warning in my e90 but the bulb lit up fine. Changed it out and the warning went away. Geuss the bulb was on its way out :
      05-14-2015, 07:04 AM   #12
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Any filament bulb will often fail by the filament breaking. For a while the filament will be flopping around attached at only one end. Then the filament will flop around, touch the other contact again and melt itself back on. Often happens with brake or turn signal bulbs. Stops working, bang the lens, comes back on.......for a little while. Won't be long before it burns out completely. And since the resistance will be different after this happens, it can trigger a failed code, even though it is currently working.
Just replace both lights, the bulbs are cheap. Like $10 cheap.
      05-14-2015, 07:06 AM   #13
mattryan
mattryan's Avatar
86
Do you know where I can get the bulbs from? Someone said the dealer charged $70 for the bulbs and $220 the program them! Also how do you get in there to change them? I don't think it's the same way as changing the AE's is it?
      05-14-2015, 07:14 AM   #14
MightyMouseTech
4338
There is a small cover on the top of the headlight you have to remove, it is a bit tricky. Search here and you will find instructions.
I believe they are just a standard H3 bulb, not sure on wattage, check the owners manual, it should say. If it calls for a 35 watt bulb, search for motorcycle H3 bulbs. May be a good idea to get one that is whiter while you are doing it.
You can even get a 35W PIAA H3 bulb for only $8.
http://www.amazon.com/70313-Super-Wh...ywords=h3+bulb
Hmm, may be time to upgrade my own cornering lights........
      05-14-2015, 07:25 AM   #15
mattryan
mattryan's Avatar
86
Awesome thanks for the info!
      05-14-2015, 08:46 AM   #16
mattryan
mattryan's Avatar
86
BTW it's a 55W bulb just checked the owner's manual.
      05-14-2015, 08:52 AM   #17
MightyMouseTech
4338
Cool, thank you for checking.
May get these then. They are also a "powersports" bulb, which should be better vibration resistance?!?!?
$36 for the pair.
http://www.amazon.com/PIAA-White-Lig...ds=h3+55w+piaa
      05-14-2015, 09:15 AM   #18
dm874
dm874's Avatar
84
Drives: 15' M4
So how does one 'program' a light bulb??
      05-14-2015, 09:17 AM   #19
MightyMouseTech
4338
Maybe they were just clearing the fault code and not actually "coding"?
      05-14-2015, 09:31 AM   #20
mattryan
mattryan's Avatar
86
$36 for the pair.
I think I may just stick with the OEM bulbs seems like a lot of people who change these ones they burn out after 2-3 months
      05-14-2015, 12:00 PM   #21
Dilmorecg
Dilmorecg's Avatar
115
Drives: 2014 X5 50i
I picked these up: http://www.ebay.com/itm/291395785480...%3AMEBIDX%3AIT
They are super cheap. So if they burn out no big deal. Ive only had them in the car a few months and no issues. I hardly ever have my headlights on though so they dont get used much.
The "white" bulbs match the HID's more is why I got them.
2014 X5 50i
      05-17-2015, 04:24 PM   #22
mattryan
mattryan's Avatar
86
Just a quick update: changed the H3 bulbs for the corners lights and the error went away. i just decided to go with the OEM bulbs as I read on a lot of different forums that aftermarket bulbs burn out way too quickly and I just didn't want the hassle. $21+tax per bulb from BMW though
1addicts
