M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      05-10-2015, 06:20 AM   #1
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Which cat back exhaust to fit that doesn't require any cutting?
I've always put a different exhaust on my M cars previously a Militek and then a Tubi but only the rear section, previously fitted exhausts have "slipped on" so no cutting needed.
Are there any that will slip on as I'd like to return the car to stock when I sell it.
From looking at the exhaust threads the one I'd like Eisenmann sport or race seem to involve cutting.
Any advice would be appreciated.
730d/Z4C
      05-10-2015, 06:46 AM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
No cutting for E Race or sport. Totally bolt on. Well, they do have to cut off your factory ones first in order to slip the Eisenmann on.
I had the E Race and so do hundreds of people ... it should take about 1.5 hrs to 2 hrs to get it measured, align, cut and bolt on.
      05-10-2015, 06:49 AM   #3
IshR
15
Drives: .
From what I know, the stock F10 exhaust is one piece. So if you only want section 3 (mufflers) changed, the stock exhaust must be cut.
Stock mufflers can be welded back on after.
If you don't want stock exhaust cut, you have to change section 2 (mid section / cross pipe) and 3 (mufflers).
      05-10-2015, 06:56 AM   #4
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Here in North America, if you want to put stock muffler back on, the better option is to have exhaust sleeves used to reconnect the muffler back to factory pipe. Seldom, you will see they are to be re-welded back on.
      05-10-2015, 07:04 AM   #5
IshR
15
Drives: .
Sounds good, how does the exhaust sleeve fix to the factory pipe?
      05-10-2015, 08:34 AM   #6
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Thanks gents so cut or go back further, pity as I love the look of the Eisenmann 120mm tips and it sounds lovely.
730d/Z4C
      05-10-2015, 08:40 AM   #7
MCarsFan
MCarsFan's Avatar
363
Drives: 2014 BMW M5 F10 CP
2014 BMW F10 M5  [10.00]
The BMW MPE exhaust is Akra full cat back system. No cutting or welding..
So is RPis exhaust..GT, GTS and GTM..
Meisterschaft and Eisenmann if you order the X pipe mid section..then no cutting either..
If you fit any cat back system, your exhaust will be removed as one piece..how you get it home is another question its 10 feet long..
2014 BMW F10 M5 ZCP | SSII / Black | MSR Stage III | MSR Intakes | RPi GTM Exhaust | RPi Catless Downpipes |RW Carbon Front Lip | RW Carbon Diffuser | RW Carbon Trunk Spoiler |
      05-10-2015, 09:12 AM   #8
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Ah OK I'm perhaps not using the right terminology to describe what I mean.
By "cat back" I think I mean the rear muffler section, on the e92 M3 this was available excluding the mid section as a slip on to the existing pipe work. (the Tubi Rumore was about 4 feet long)
Like this:
The MPE and Akra are far too rich for me I couldn't spend that on an exhaust £7,000 + fitting in the UK.
It's just the mufflers I want to change and from what I've read here that will require cutting.
Sorry if I'm reading this wrong and thanks for the help!
730d/Z4C
      05-10-2015, 09:34 AM   #9
MCarsFan
MCarsFan's Avatar
363
Like this:
It's just the mufflers I what to change and from what I've read here that will require cutting.
Ah. Axle back..really like the Eisenmann race black series..but you'll have to cut off your stock rear mufflers..Awesome throaty sound..
If you reinstall..use clamps to reattach.. Put me off..not sure about sleeves but sounds better..
Beautiful set was for sale with low miles in classifieds here in the U.S..
GBP getting much stronger after the election..so you're getting a good deal if you ship?
Just took another look..there's also an Akra for sale at good price..
m5post
