      05-05-2015, 02:33 AM   #1
Juan35i
SSG
Juan35i's Avatar
Drives: 2009 135i
2021 BMW M2 Como  [10.00]
Xenon Light won't turn on!
Driving to work las night under heavy rain my car hit a kind of big water spot. Short after I got a error light on the dash and now the driver's side headlight won't turn on. Any ideas on how do I find out if the bulb is burned or the ballast (where is the ballast located on the headlight?)
      05-05-2015, 05:01 PM   #2
SchismX
SchismX's Avatar
Germany
37
Drives: '10 135i
The first thing you could try is to swap your bulbs to see if the problem follows to the passenger light. If not it could be your ballast/control unit, which is located on the bottom of your headlight assembly. You will need to remove the headlight to have access to it. It would also be a good idea at that time to open it up and dry it out the best that you can.
Good luck
BMS DCI // Catless DPs // BMS OCC // BMW PE // ER CP/TiAL BOV // VRSF 7" FMIC // JB4 + MHD // SSR GT1 // Alpina TCU flash
      05-06-2015, 02:39 AM   #3
Juan35i
SSG
Juan35i's Avatar
Drives: 2009 135i
Good luck
I did swaped bulbs and they were fine. Then I removed the bumpers and headlights and dried out the ballast with a blower and plug it back in. Voila working perfectly fine..
      08-24-2015, 01:39 PM   #4
mwantedc
Drives: 2008 BMW 135i
New guy with 135i headlight will not turn on
Hello,
I'm new to the forum and at the same time experiencing an issue with my xenon bulb I recently replaced in passenger side front.
my RHS bulb went out, so I replaced it still the same thing., D1S bulb
Wondering if there any fuses that follow to that might be causing the issue
any help, will be greatly and I mean greatly appreciated
      08-24-2015, 02:03 PM   #5
JL135i
27
Drives: 135i
Originally Posted by mwantedc
Hello,
There are a couple things that could happen regarding the headlight bulb d1s not working.
Blown fuse (check your fuse box)
Light control module is faulty (you have to open up the bottom to see)
The silver wire that connects your light control module to your light bulb is corroded (open up headlight to see)
Those are the only things I can remember off the top of my head. If you can tell me when your headlight went out and what conditions it was in I can help you more.
1addicts
