04-23-2015, 11:43 PM | #2 |
5437
Rep 8,809
I'm sure its possible but the question is why would you want to do that? I am sure Bmw M put staggered wheels on the X5M for a reason besides looks. The only reason I could think of is if you are using it for a winter setup which makes sense.
04-24-2015, 09:20 AM | #4 |
359
Rep 729
Have you looked into doing all-seasons on the staggered setup? On the E70 X5 with staggered 20" rims, people were able to run all-seasons. I believe the popular one was Continental DWS.
04-24-2015, 09:22 AM | #5 | |
Rep 34
There are no All seasons available for rear ones. May be they will release later. I wanna know if front wheels will fit And be Ok in the rear. |
04-24-2015, 09:39 AM | #7 |
603
Rep 1,206
You need the same rolling diameter, the x drive is very sensitive. Buy a pair of winter tires, you will spend 110k spend and balk at 3k to get another set. All seasons why did you even bother buying the M car could have saved yourself 30k.
I didn't know I couldn't do that. But I did know I couldn't do that.
04-24-2015, 09:53 AM | #8 |
Rep 34
Don't wanna go through the Pain of changing wheels twice a year. I bought anM Car with an X. I might have to do the winter set in the end but I don't think exploring options is bad.
FYI the winter sets are also 19s All same. Not staggered not 20 or 21. |
04-24-2015, 10:31 AM | #9 | |
1644
Rep 2,775
Drives: F95 X5MC
http://f15.bimmerpost.com/forums/sho....php?t=1068441
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
04-24-2015, 11:49 AM | #10 | |
147
Rep 535
The oem staggered wheels will easily last you 2 years unless you track your car.
My 2015 Hartge X5 50i build journal
http://f15.bimmerpost.com/forums/sho....php?t=1035887 My 2016 F80 M3 build journal http://f80.bimmerpost.com/forums/showthread.php?t=1166600 |
04-24-2015, 06:44 PM | #11 |
151
Rep 517
Drives: 2024 XM Label
+1
The non-staggered setup will diminish handling, traction, and aesthetic. They're put there for a reason 19" All seasons are fine on a 30d, but they're an annual compromise - they suck in all seasons, but less than the wrong tire. You may as well not have bothered with the X5M to start with. It's not a big deal to add a winter set, and your dealership will likely store it for free. I go in in November, have a coffee and a muffin, and wait while they switch out my rims from storage, mount them all, and check the air. Same in reverse in ~March. It's $40, twice a year. The rims will usually sell for ~70% of their original cost after a few years too. |
05-05-2015, 11:31 AM | #12 |
514
Rep 1,437
Id love to know the compatibility of wheels from the E chassis to the F chassis. Is the center bore of 72.5 rear and 74 front still the same?
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
05-05-2015, 12:44 PM | #13 | |
28
Rep 228
that said, your rear end will look really lame with skinny tires under flared wheel arches during the summer. should have bought a cayenne - square set up std save for a bit of extra spacer on some models |
05-05-2015, 02:12 PM | #14 | |
83
Rep 377
05-06-2015, 09:28 AM | #15 |
514
Rep 1,437
If so, that would be great. Thx man
05-13-2015, 09:22 PM | #16 |
1383
Rep 3,834
Use this tool to calculate rolling diameter (especially comparing front to rear):
http://www.rimsntires.com/specspro.jsp
Daily: G12 750 MSPORT Weekend Car: E90 M3
