04-23-2015, 07:35 PM | #1 |
33
Rep 235
SNI-35 or LC-2
I'm looking to have a JL W6 and amp installed (1400.5), I've had the same setup in every car I've owned and never needed a converter. I had them installed in my E92 but I never got a lot of power from the sub some I'm guessing this is necessary on BMWs. Every stereo shop I call tells me a different story, the LC-2 is a bit more advanced but I'm trying to figure out if I can get away without either or at a minimum the SNI unit. I'm not overly concerned with the adjustments that can be made with the LC-2, I just want some extra bass.
Can I get some decent power without either unit, or do I have to have the LC-2?
2018 F15 X5 - Alpine
2015 F82 M4 - Yas Marina 2010 E92 M3 - Alpine White - Sold |
04-23-2015, 07:46 PM | #2 | |
2288
Rep 13,001
If your system is the HK then your only choice so far will be the LC2i. The LC2i active LOC is used the HK OEM system due to the 30V+ peaks of the OEM amp woofer outputs. The LC2i withstand up to 40V. The PAC only ~12V. |
04-23-2015, 08:02 PM | #3 |
33
Rep 235
I have the HK system, thanks for the reply! Any idea if this was why I couldn't get any power on my M3 (had Enhanced Premium Sound/Bose)?
04-23-2015, 08:15 PM | #4 | |
2288
Rep 13,001
So most probably the first bass peak saturated the inputs of whatever amp you were using. |
