04-22-2015, 11:46 AM | #1 |
42
Rep 131
Questioning my 135i Purchase immediately...
Just a little venting/PSA...these cars can be PRICEY to fix. I just bought a 2011 CPO 135i two weeks ago. I have about a year left on the CPO warranty. Over the weekend I got a "passenger restraint system malfunction" warning and two idiot lights on the dash. I took the car in to BMW and it is a seat pad sensor (that tells the car if it should turn the airbag on or off). According to the dealer, this is $2100 in parts alone, because the sensor is sewn into the upholstery. Luckily my CPO warranty will cover it. However, if a seat sensor is going to cost me that much in the future, what is a major mechanical problem going to cost?!
I know some of you will reply that I shouldn't go to the dealership because they are expensive, and I won't once I am out of warranty. However this part is over ~$1200 on the internet. I know you have to pay to play, but WOW! That said, I love the car so far /rant over |
04-22-2015, 11:54 AM | #2 |
423
Rep 887
Go extensively research extended warranties (i.e. EasyCare), pick one from a provider that covers EVERYTHING, and pre-empitvely spend $2-$3K on it a year from now when the CPO is up. Now, stop worrying and go enjoy your new purchase.
04-22-2015, 12:02 PM | #3 |
209
Rep 893
Personally, I share your concern. I can do simple maintenance... but for the harder stuff, I don't have an indie that can work on these cars and the closest dealer is 15 miles away. I have about 18mos of CPO remaining; I'll evaluate what to do before that time comes. No issues with the car so far (six months).
Regarding your seat sensor... is just that part available (without the seat cover)? Sewing a new one in is less work than you might think, a guy can get the cover off the seat bottom pretty easily (I outright replaced the driver leather on my previous car, it's surprisingly easy).
2011 135i MSport 6MT AW/black, 72Kmiles, bone stock, moneymoneymoneymoneymoneymoneymoneymoneymoneymoney I LOVE THIS CAR
04-22-2015, 02:05 PM | #6 |
52
Rep 374
Definitely. Every little electronic components worries me a little bit and sometimes I wish I didn't get the premium and tech packages. I got another 2 years on my warranty and although I probably won't be getting any extended warranty afterwards, I'll definitely be putting aside some money per month for possible issues that might come up.
04-22-2015, 02:09 PM | #7 |
850
Rep 2,276
Its definitely safety related and I'm sure the NHTSA would like to know about this. A simple seat switch shouldn't fail that quickly (read defect). Now, once the car is well out of warranty, the seat switch should be just a switch, most likely open when nobody in passenger seat and closed when there is. I know what I'd do.
04-22-2015, 02:10 PM | #8 |
4338
Rep 6,196
Just curious. Is it possible the seat got wet? That can trigger many seat pad sensors like that. Sometimes just letting it dry out and resetting the SRS computer is all that it needs.
04-22-2015, 02:14 PM | #9 |
42
Rep 131
I actually read that, but no. The seat hasnt gotten wet since I've owned it.
04-22-2015, 02:16 PM | #10 |
138
Rep 353
At some point, especially when out of warranty, DIY and used parts are the way to go. A single used sport seat costs about $400-$500 shipped. I bought two of them to replace my non sports seats. This would have fixed the problem above. Dealership is stealership when there is no warranty
04-22-2015, 03:45 PM | #11 |
Chief Warrant Officer
1025
Rep 1,638
Yeah, I can't imagine that it can't be replaced with a much simpler pressure switch. Weight on: closed. Weight off: open.
I'd be willing to bet you could build/buy a DIY substitute for $50 or less. Sure, it wouldn't be BMW OEM, but if you're like me, you didn't buy this car because it's a BMW, you bought it for the awesome machine that it is. If it had a Hyundai badge but was the exact same machine, I would still own it. So, back to the point: a DIY pressure switch would be easy and inexpensive if you were out of warranty. (Plus it's under the seat-nobody would know its not original).
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
04-23-2015, 10:11 AM | #13 |
24
Rep 177
i feel your pain. i just spent $2300 (down from $2500) to have oil filter housing, oil pan and valve cover gaskets changed; new oil; new spark plugs; coolant flush. the car just turned 90k so i knew it was coming.
i also had an issue with the passenger side seat, but warranty covered it. i then had an issue with the driver's side, but it was a wiring snafu and still cost me $600. in the end, i guess its the cost to drive a bimmer! |
04-23-2015, 10:37 AM | #14 |
912
Rep 1,850
Car upkeep out of warranty is a gamble and the odds are not in your favor in the long run. You do have to pay to play, however, the cost can be a lot less if you're willing to perform sometimes difficult work on the car yourself and accept reduced functionality--such as would be provided by a simple switch or hard on / off of the passenger airbag.
04-23-2015, 12:12 PM | #16 |
Joint Chiefs of Staff
24198
Rep 190,805
I question my 335 purchase often, but as soon as i got WOT i know i made the right decision
04-23-2015, 12:13 PM | #17 |
43
Rep 170
At this point you have to call a spade a spade.
BMW/Mini has had a continuing problem with the seat mat sensors; had it on my 09, known problem on E60's and recently: http://www.edmunds.com/car-news/2005...g-problem.html
The Black Prinz | 09E82N51 | BMW 3-Stage Intake Manifold | BILSTEIN B12 Pro-System+ | ///M Control Arms | ///M Bushing kit | ///M Strut Brace | DINAN Camber Plates & Rear Shock Mounts | ECS Performance Trailing Arms | aFe Magnum Force Intake System [Dynamic Air Scoops+Stage 2 CAI] | BMW Performance Exhaust | BMW Performance Brakes | GOODRIDGE G-Stop SS | DEPO V2 | Style 220M reps |
04-23-2015, 12:15 PM | #18 |
209
Rep 893
There is no issue if you have no friends
04-23-2015, 04:39 PM | #19 | |
137
Rep 439
Edit: Just remembered, two of the window regulators failed - but other than that.... Last edited by KNS; 04-23-2015 at 05:47 PM.. |
04-23-2015, 04:53 PM | #20 | |
209
Rep 893
04-23-2015, 05:34 PM | #22 | |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
I had my 1994 E36 for 18 years, 120K miles... The only major problem was a blown diff at around 70K.
