      04-17-2015, 03:04 PM   #1
wantsasheep
wantsasheep's Avatar
14
Drives: E93 M3
What does this connect to?
Hello!!
I just recently replaced my 3 series for my beautiful 2010 128i...
Playing around with it I found a loose connector. I am guessing it is the horn connector since my horn doesn't work (and I can't find it under the hood!)
Any insight?? There is one on each side
Thanks!!
      04-17-2015, 03:30 PM   #2
Tinsta
Tinsta's Avatar
189
Drives: 1CSL
Have you checked the fuses? could be a blown fuse perventing the horn from working. Where abouts did you find these cables in the engine bay? horns are located on the rightside under the headlight, if you take the lower arch liner off, you should be able to see the horns (2 on the bracket).
1addicts
