04-13-2015, 06:55 PM | #1 |
142
Rep 324
Drives: 2018 M2 Black Shadow Edition
Autocross Tires
I attended my first autocross school with the BMW CCA this past weekend at the Devens airport in Mass. What a blast taking this car to it's limits, and beyond a few times.
The car handled well and felt balanced but my tires were clearly holding me back. I have 4 season Yokohama ZPS tires, which I thought were "high performance" but are clearly not meant for autocross. So, what tires to get for my next autocross event? Ideally i'd like to get a runflat high performance summer tire to put on my 17" rims. And then i'll grab a cheap set of rims and Blizzaks for the winter. Recommendations for a daily summer driving & occasional autocross tire?
04-18-2015, 06:22 PM | #2 |
185
Rep 505
Drives: 2010 128i 6MT Sport Pkg. 18"
Check out the "Tire Rack" reviews in the performance category you're interested in. Lots of good choices from all the major manufacturers. Something from max. performance summer tires should suit you. Top honors often seem to go to the Michelin Pilot Super Sport but again, there's lots of choice depending on budget. Might want to look into getting away from runflats. You'll have a lot more choice of better tires for less money. BIG improvement in ride. Easy enough to pick up a small jack & donut spare.
04-18-2015, 06:42 PM | #3 |
1Addict
3233
Rep 7,894
all seasons won't grip nearly as well as a max summer tire. or you can go extreme category, which would probably be better.
04-19-2015, 03:22 AM | #5 |
43733
Rep 7,224
Technically, not true. Tire Rack sells ultra high performance summer run-flat tires, maximum performance summer run-flat tires, as well as high performance summer run-flat tires.
04-19-2015, 06:04 AM | #6 | |
460
Rep 4,531
So take those and try to run them against a Hankook RS3 or any actual high performance tire. Let me know what the outcome is. It's like saying you can have high performance all-season tires too |
04-19-2015, 08:12 AM | #7 | |
161
Rep 282
Agree
Be advised that some untra-high performance Yokohama, Toyo, and the Nokian Z suffer cold compound cracking if exposed to below freezing temps - even if they are not mounted and just sitting in an unheated garage. |
04-19-2015, 08:25 AM | #8 | |
43733
Rep 7,224
Some of these run-flats are ranked higher than regular high performance summer tires in Tire Rack's passenger tire survey section, which means a lot of people are happy with them. I run maximum performance summer run-flats and am perfectly satisfied with them. They drive just as I expect them to, and on occasion, I've been known to drive very spiritedly. I dont race or autocross, and never will so I don't claim to be a race car driving expert and will never be comparing them to other tires on the track. For my purposes, they do just what I want. Plus they have the practicality of a run-flat. Since I've had my 2011 135i I have had two flats, and both times I was able to drive to the local tire shop and get a new tire. The last thing I want is for my car to be towed. That hasn't happened yet and never will, at least due to a flat, and I can thank my tires for that. I'll take a little less performance for that convenience.
04-19-2015, 02:11 PM | #9 |
34
Rep 504
I've ran a few events on the perreli Eufori@ that came with my car and also the PZeros i have on it now. they work alright, but they are not the best tool for the job. i think they are both discontinued though.
what tire pressure were you running at the event? that can make a huge difference on handling at an AutoX. I put 12,000 miles on my summer set a year, and maybe 1-2 autoX events a year. I personally couldn't justify buying a third set of dedicated rims for AutoX or sacrificing my trunk by putting a spare in it since it is my only car. I've always wanted to run this car on a set of Hankook R-S3's. I hated the blizzaks RFTs I had for winter at first. I have a setup of Dunlop winters on now and I love them.
2008 BMW 128i
2022 BMW 330e |
04-19-2015, 03:05 PM | #10 |
43733
Rep 7,224
I recently bought a set of Pirelli P Zero run-flat tires for my 135i with DOT dates in the 2015s. Not sure if that's the same tire you're talking about and not sure if Pirelli still makes them but that is a pretty recent manufacturing date as far as tires go.
04-19-2015, 09:30 PM | #11 | |
460
Rep 4,531
This thread is about autocross. If you want to be competitive, and have the best tires. Best you stick away from run-flats |
04-19-2015, 10:13 PM | #12 |
43733
Rep 7,224
Thanks for the advice but I don't care about being competitive, and I think tire manufacturers and Tire Rack know a little more than you about what a "high performance" tire is.
04-19-2015, 10:19 PM | #13 | |
460
Rep 4,531
Because the reviews are purely based off of customer review, and can be high biased depending on the customer base and type of tire. Perfect example: http://www.tirerack.com/tires/survey...ay.jsp?type=EP Extreme Performance tires shows that the RE-11A is the ZOMG BEST TIRE OUT THERE due to surveys. However, I dare you to waste your money on that tire. Pull up any National SCCA autocross and you'll find out no one in their right mind would ever mount that tire for their car. It's absolute garbage. However, you'll see Hankook RS3v2, Dunlop ZII*, BFG Rival and Rival S, BFG RE-71R all mounted on cars, and winning. I don't know who you think you are, but you definitely don't know me. Who cares that I've ran Dunlop ZII, Hankook RS3s and soon BFG RE71Rs and can tell you the exact differences between them. I clearly do not know anything at all. It's not like my car is prep'ed purely because I autocross it and have it modified to the extend of the rules or anything. Because anyone who does that just doesn't know anything about tires. Well guys, looks like I gotta sell my tires and follow exactly what the surveys say because I'm wrong. If you're not competitive, then you shouldn't be posting here. OP didn't ask to finish last. |
04-19-2015, 11:05 PM | #14 |
43733
Rep 7,224
One more thing I'd like to add, the OP said he'd like to get a "runflat high performance summer tire," so why not steer him in the direction he'd like to go?
04-19-2015, 11:11 PM | #15 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
It would seem that someday a manufacturer will make a runflat that will perform on a track as well as a non-runflat. Then they'd also have to make them as cheap as non-runflats before they would be worthwhile for someone who autocross/tracks their car, since they have to replace their tires much more than the rest of us.
This thread was about autocross tires. The tires KGolf mentions are the choices to go with. I'd probably go with ZIIs if it were me if they come in the sizes you need.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
04-20-2015, 02:33 AM | #16 | |
460
Rep 4,531
04-20-2015, 04:58 AM | #17 | |
43733
Rep 7,224
By the way, you're not a moderator and you might be large, but you're definitely not in charge so don't try to tell me where I can post. Comprende amigo?
04-20-2015, 07:25 AM | #18 |
142
Rep 324
I did some research.
I'd like to get these for summer & autocross: http://www.tirerack.com/tires/tires....port%20Package But these would be more practical, you know, i case I get a flat tire: http://www.tirerack.com/tires/tires....omCompare1=yes I know and agree that i'd lose a bit of performance with the run flat but I need to consider that I may do 2 or 3 autocross events at the most in a summer, so the trade off might make sense.
04-20-2015, 07:41 AM | #19 |
4338
Rep 6,196
No offence, but this is terrible advice. The OP is asking about autox tires. If you don't know anything about autox tires, maybe leave it to people who do. Running a RFT tire is terrible advice, I don't care what marketing term Tirerack uses.
04-20-2015, 08:39 AM | #20 | |
460
Rep 4,531
Anyways, I had to chime in because you're offering terrible advice. Yes, OP said he would "ideally" prefer a RFT tire, but IMO he'd still be very disappointed. For reference, I've driven close to 15,000 on my Z4M and 30,000 miles on my 128i without runflat tires. Multiple trips excess of 600 + miles there and back with nothing. RFT tires will make the car feel numb, and kill any handing characteristic of the car. High performance or not the sidewall has no flex in it, which is one of the major components of a tire. But I don't know anything and have never done this before... |
04-20-2015, 10:47 AM | #22 | |
161
Rep 282
Just remember
For my area and my driving, run-flats are worthless. Living in the west and driving a lot of long trips for fun in rural UT, NV, AZ, NM, I am often 50+ miles from the nearest tire store so a flat in run-flats is still a tow. In fact, this is even true for long portions of the drive between Vegas and LA. Also, your everyday garage does not have the special equipment needed to replace a runflat, and the probability of having an exact replacement runflat anywhere within 100 miles in a rural area is virtually zero. I run regular tires and carry a spare which I just used a week ago when I got a tire pressure warning 75 miles from the nearest tire store in AZ while traveling I-40. IMO runflats are worthless in the west unless you rarely drive out of the city, but Ok for you guys in the NE |
