04-06-2015, 04:48 PM | #1 |
175
Rep 500
HUD - reflection on windshield
I have noticed when the sun is high in the sky a reflection on the windshield from the HUD device can be annoying.
I tried to capture a photo while driving, it is more annoying in real life than in the photo - see below. Has anyone else observed this? Any suggestions to prevent/reduce this? Thanks |
04-06-2015, 05:21 PM | #2 |
234
Rep 512
The right sunglasses will block it out. My Maui Jims block the entire HUD display but my cheaper polarized Oakleys do not block the HUD display but they do block out the reflection. I only see the reflection when the sun is bright enough to need sunglasses so it works perfect with the Oakleys.
04-06-2015, 06:33 PM | #3 |
Blocked from G80/G82 for having an opinion
3498
Rep 3,729
It is kinda annoying so I know what you're talking about. Seems like an inherent issue with having HUD across generations. I've just learned to ignore it and only recalled how annoying it was once you mentioned it.
04-06-2015, 07:22 PM | #4 |
137
Rep 236
Drives: Various
Noticed the same. I attempted at playing with the display setup, but nothing fixed it. I just decided ignore it.
04-06-2015, 08:38 PM | #6 | ||
1904
Rep 5,678
OP... every car I've driven in with a HUD had some dash reflections and not much you can do. I don't even notice it any longer
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
04-06-2015, 11:27 PM | #7 |
175
Rep 500
Thanks. Was wondering if everyone with HUD experiences this or I needed to clean my HUD device or something. Sounds like not much we can do about it.
04-06-2015, 11:42 PM | #8 | |
11827
Rep 15,400
I had a hud problem for a few weeks too. A really sharp golden reflection.
I'm happy to say I found my missing sunglasses that would've helped with this problem if they had not been the problem in the first place. Rick I suggest the age old get a bigger problem and the old one goes away approach. The reflection used to annoy me too but not any more!
04-07-2015, 08:56 AM | #10 |
Curiosity Killed the Cat
241
Rep 822
I get the reflection too on very sunny days. I have polarized Oakleys and they do help. I mostly just block it out
SOLD - 2015 /// F82 M4 / AY-SO
"AY-BRAVE" I'M BACK - 2016 M4 GTS I'M BACK AGAIN - 2021 M4 COMP FPB |
04-07-2015, 01:55 PM | #11 |
Rep 34
Drives: 2015 M4 SO
No problem with mine, you need to add more info to your display
04-07-2015, 01:57 PM | #12 |
3498
Rep 3,729
Just curious, is that the M mode display and can you add more info to that display? The previous gen HUD M Mode is pretty barren (just like pictured) with a somewhat useless tach (only good as a shiftlight).
05-03-2015, 01:48 PM | #13 |
14
Rep 58
Wow. What a view!
Current - May 2015 F82 M4 - Austin Yellow / Full Black Leather / DCT / Fully Spec'd.
Previous - May 2014 640d M Sport Gran Coupe - Alpine White / Individual Opal White Merino Full Leather / Fully Spec'd. Previous - Nov 2009 E92 M3 Dakar Edition |
05-03-2015, 01:56 PM | #14 |
687
Rep 663
It's like that on my 335 too. It's only bad on very bright sunny days, and also depends on your position relative to the sun. Even if it's very bright out, you might not see this at all depending upon which direction you're driving in. I've only noticed this about 3 or 4 times since I've had my car. Of course, being in PA, it's gray and gloomy outside half the time, so I suppose this could be a much bigger issue in AZ, NV or CA.
05-04-2015, 02:02 PM | #15 |
Rep 4
HUD Reflection
They all do that, yes really. I have to wear non-polarized sunglasses to see the HUD clearly. You can increase the brightness. Try that.
05-05-2015, 09:40 AM | #16 |
163
Rep 641
Move here it isn't sunny very often
M2 competition, Alpine White
Previously Owned : X3 M 40i, F80 M3 Comp Pack, DCT, Yas Marina Blue, F80 M3, DCT , E92 M3 Comp Pack, E92 M3, Z4MC, E46 M3 CS, E46 M3 |
05-05-2015, 02:18 PM | #17 |
442
Rep 601
Drives: 2015 M4
In my E60 M5 the HUD was also in color. As the RPMs increased it would go from green to yellow to red for red line. Does this one do that, or does it always stay gray? I haven't had the break in service done - not sure if they change it.
