04-06-2015, 12:11 PM | #1 |
Rep 34
Lens diameter on DEPO projector
Hey Everybody,
I was wondering what the diameter of the DEPO projector is? I was considering putting in a new projector but I am unsure if its 2.5" or 3.0" Thanks |
04-06-2015, 02:46 PM | #2 |
1555
Rep 3,234
Have you tried contacting them?
I believe the diameter is 2.0", maybe 2.5" but definitely not 3.0" What projector were you planning on retrofitting?
2012 BMW 128i 6MT Deep Sea Blue Metallic
04-06-2015, 10:45 PM | #3 |
Rep 34
I will definitely check the diameter when I have time to drive but I figured if somebody knew
I have some pretty good 3.0" options like the RX 350 or Hella e55 but 2.5" would be a bit more complicated... I'd assume it would be something like the FX-R |
04-07-2015, 06:08 AM | #4 | |
1555
Rep 3,234
04-07-2015, 11:56 AM | #5 | |
Rep 34
Just a thought: the mini's are also 3" lenses and because the DEPO's are somewhat based on BMW's design, I would assume they mimic the Hella E55 which would be the start projector in a 128i which happens to also be 3". I guess I want OEM performance if not better, not sure the mini's can deliver that |
04-07-2015, 01:15 PM | #6 |
1555
Rep 3,234
Bmw uses Bosch bi-xenons from the e46 I believe. The issue doesn't occur with the lens of the projector but lies with the length of the body. Depo does in fact use 2.5" lens but you must take into account the size of the body of the projector.
This is my reasoning behind suggesting the morimoto mini series.
